Urge to kill rising... Weather stripping on pop outs
I'm trying to convert my SC to pop out windows. I took the weather stripping off to paint the frames and am now having a hell of a time getting them back on. I've spent close to 3 hours on one and I still have not made any progress.
So, besides warm soapy water, strong hands, rubber mallets, paint can opener and a rounded off screw driver, are there any other methods?
Anyone in NJ want to make a few bucks?
Please someone save me from this hell!
Old 10-24-2014, 04:09 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Is there a lip you can put string or insulated wire into?
1981 911SC Targa
Old 10-24-2014, 04:20 PM
Shaun @ Tru6's Avatar
This can be an easy job. Just fill your bathtub with hot water, stretch the molding around the quarter windows and then let them sit in the tub for about an hour.
With a dulled screwdriver, they pop right on. I fought with my mine for 2 hours before doing this, 30 minutes after coming out of the tub and they were ready to go.
I am not sure if this will work if you have a wife.
Tru6 Restoration & Design
Old 10-24-2014, 04:21 PM
Bob Kontak's Avatar
Shaun may have a better idea.
1981 911SC Targa
Old 10-24-2014, 04:22 PM
I got a big slop sink. I only soaked then for a few minutes. I'll try again.
Old 10-24-2014, 04:35 PM
Well that didn't work. Trying again with some slimy soap.
It seems every time I think I have it I look and the previous spots came out.
Old 10-24-2014, 06:02 PM
djporsche's Avatar
Wd40
57 Porsche Speedster Replica
69 VW Squareback Automatic
80 911 SC Weissach
06 Cayman S
Old 10-24-2014, 06:12 PM
I'm able to get it in the channel but as I work my way around the window it pops back out.
Old 10-24-2014, 07:08 PM
Although I have never done a set of quarter windows I have had luck in the past with similar situations by boiling some water in a large turkey fryer. Turn off the heat and then put the rubbers in the water to soak for a bit. They will get nice and soft and should go on easily and stay on as they cool.
'83 911SC Targa
Former
'73 914 1.7
Old 10-25-2014, 06:51 AM
I have admitted defeat after waking up to a pair of sore hands. They are now at the glass shop with a dude who's done them before. He wasn't happy to see mine!
Old 10-25-2014, 07:11 AM
Did you get aftermarket seals?
Old 10-25-2014, 07:55 AM
OEM seals.
Glass place did it in an hour. $60 for both. I should have done that sooner. I believe they used silicone.
Old 10-25-2014, 09:32 AM
strange, mine were cake after soaking. glad you got it done.
Old 10-25-2014, 09:51 AM
gptom's Avatar
Which corner is the best place to start the seal?
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 10-25-2014, 12:02 PM
Discseven's Avatar
Never heard of pop out windows Scott. Sounds interesting. Photos? If you are dealing with windshield, and for reference to others since you're getting it done... it's very easy to put molding in when windshield is out of car because you can sort of peel back rubber to open receiver slit. It's also much easier to shape molding to glass because pressure can easily be applied from both sides---very difficult to do when glass is installed. Putting glass back takes a few minutes with string pull so easier to remove glass and put back.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 10-25-2014, 01:46 PM
techweenie's Avatar
Originally Posted by Sicklyscott View Post
OEM seals.
I've had cooperative ones and uncooperative ones. I've accumulated about 8-9 pop out quarter windows just to harvest the seals. OE seals that are 5-10 years old are pretty easy to install. The vertical section at the front is always a battle.
Next battle usually is getting the 4 little holding screws into the back of the b-pillar. Use a tapered punch to align and practice your breathing/mediation techniques.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-25-2014, 02:16 PM
These are the rear quarter windows. They are fixed on the sc and carrera cars but pop out or vent (like mini van rear windows) in the older cars.
Old 10-25-2014, 07:38 PM
Quote de Sicklyscott
OEM seals.
I've actually had these in and out of the car several times for tapping and drilling, fitment questions and to touch up some paint. Not too worried about this portion.
Old 10-25-2014, 07:39 PM
Wish I had seen this earlier. I converted my SC to pop outs a couple years ago. Despite all the pain, it is definitely worth it.
I literally wanted to throw my pop outs off my porch when doing the seals. I would get it wrapped all the way around then trying to get the flat portion fitted, the seal would completely pop out.
Eventually, I found this thread.
Rear Quarter Window Weatherstrip - I Have the Fix!!!
I used no soap, no silicone, just the paint can opener trick and had both installed in minutes.
Old 10-27-2014, 05:42 AM
