The costs on 3.4 P&C, cams, throttle bore plus labor should be 1/2 that? Of course thats not taking into account the other possibilities with the heads once they are off. Either way its a slippery slope. |
Trader,
You are right. A 3.6 swap with be around triple what you have for a budget. |
I am wondering what I would get for the 3.2 in my car now to defer costs?
If you do the 3.4, and refrain from taking apart the bottom end and whileyoureintheretitis you might stay within a reasonable budget. Who's doing the labor, you? So here's three 3.4s built and tuned locally on a Dynojet, using the stock exhaust setup on 91 octane. One of them was built by TRE, and another Callas Rennsport. I forgot who the third was by. You can see the shift in midrange torque vs top end HP dependent on things like cam timing: http://forums.pelicanparts.com/uploa...1415122379.jpg |
Built for racing: stronger rod bolts and/or rods, titanium valve hardware, race fuel, headers with Cup car loud open exhaust, extensive dyno tuning ...
However, I don't think at his mileage and with his goals, Trader isn't even going to need to crack the case or remove the rods. Just install the P&C on the still assembled crankcase and rebuild from there. |
Unfortunately I don't possess the skills or have the time to do the work myself. This thread has been a tremendous help on the other hand its also opened up to a huge number of possibilities.
?????? 3.4P&C's Cams Head Work Throttle Bore Any idea on what the above work / parts will run? Will they work okay with the pieces below? Already have: Stock Heat Exchangers M&K Pre Muffler M&K 1 in 2 out Steve's 93 Chip. |
Yeah, I was woundering how he was going to pull that off for 7k. ;)
As a data point I recently got a quote to convert to 3.4 single plug with Mahle keeping all else stock from a well regarded local shop. Their quote was just under 15k including labor, taxes, shop fees etc. I am guessing if I add in new cams and bore the throttle body I will be closer to 17k all done.
Also one thing to keep in mind is a 3.4 with Mahle will have a much higher re-sale than a 3.6 conversion as the Max Morrittz conversion is considered period correct. It can also go un-noticed/pass for stock which is a great benefit in many countries with strict laws. |
just saw that you have the M&K premuffler, muffler and chip...
is there any reason your engine is not already at 230HP? That doesn't make much sense given that there are stock motors (extensively tuned with the magic formula) that are putting 260 to the wheels. |
These motors also have every trick in the book throne at them. Little things start making a difference. Rod bearing clearances, massaging everything to get a little more compression, it all adds up. A light weight flywheel can show 4-5whp gains on a DynoJet, slight difference in air filter adapters to the AFM can be worth a couple HP, changing the engine fan pulley ratio to that of the early cars is worth a few more to slow the fan speed down. Running a 226mm '78-'79 SC fan at the early 911 fan speed is worth another 5hp or so. It all adds up. As far as a budget approach. I have watched a truly stock US spec 3.2L with a stock aluminum clutch and full weight flywheel, 1-5/8" Euro headers, phase 9s, and nothing more then a good valve job, careful attention to the AFM, 226mm fan, and a custom chip by Steve Wong consistently put down just shy of 230whp on a DynoJet so it is possible. |
| All times are GMT -8. The time now is 12:00 PM. |
