-   -   Hood should close upon dropping or does it require (http://forums.pelicanparts.com/porsche-911-technical-forum/836505-hood-should-close-upon-dropping-does-require.html)
Jdub 10-31-2014 07:02 AM
The definitive response:
Front: Spread both hands wide, on either side of the crest, close to the lip of the hood where underside support is best, and gently but firmly push down.
Rear, right-handed owner: With the left hand holding the hood at level, place the right hand on the grille, and then let go with the left hand while pushing down with the right hand.
pmax 11-05-2015 11:03 PM
Well, according to this video (7.30) , the crest was designed to be used ... for the 993 at least.
https://www.youtube.com/watch?v=tVm09RAU6KQ
DRACO A5OG 11-06-2015 01:11 AM
Whoa, kinda of an old thread, no? :D
One can adjust it so you do not have to push so hard to close. As long as it clicks on the final latch. it will stay nice and locked.
Pazuzu 11-06-2015 07:27 AM
Why not just move the latch with your fingertip, like you do when you open it? Then it takes zero effort to latch closed, no bendin', no pushin', no distortin', no nothin'.
bdisco 11-06-2015 07:57 AM
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&u act=8&ved=0CBwQtwIwAGoVChMIoOja95P8yAIVwvI-Ch1sEgoU&url=http%3A%2F%2Fwww.youtube.com%2Fwatch% 3Fv%3Dphrzll4Us9w&usg=AFQjCNFsk7FZtbeVSZ99DvcMLxjP UotSmw
http://i.ytimg.com/vi/phrzll4Us9w/hqdefault.jpg
:eek:
T77911S 11-06-2015 08:25 AM
i push at the front edge where the hood is stronger, dont want to put a dent in it.
universeman 11-06-2015 09:42 AM
Fingertips to left and right of the crest is how I do it. I think that's the recommended way. Light pressing on the crest is probably fine, but too much and you'll get a dented hood.
gtc 11-06-2015 10:42 AM
Press down directly over the latch.
Pressing on the crest makes no sense whatsoever.
