-   -   First time height & alignment project - help wanted :) (http://forums.pelicanparts.com/porsche-911-technical-forum/837262-first-time-height-alignment-project-help-wanted.html)
Discseven 11-05-2014 08:19 AM
Background
Recently loaded 205/55 front and 245/50 rear to see if a few dollars could be saved over going with 205/50 and 245/45 combo. We're talking 16" wheels... 8" front and 9" rear. $370 total for the larger 4 tires balanced & mounted. Unfortunately, these larger diameters don't fit a 911 as my eye sees it--slightly too large IMHO. So, back to original 205/50 F and 245/45 R. Guys at Tires Plus (Bird Rd. near Vertex in Miami) were kind enough to take 4 new tires I "broke in" back without objection (as long as I was willing to spend more $s on smaller tires.)
Reason for DIY alignment
I've never had tires wear evenly on this 911. They consistently suffer on insides. Thought "reputable" shops were doing my alignments but it's increasingly evident in general that few shops genuinely know what they're doing. Jaded? Yup. Justified? Think so. Now, am going to see for myself WTF is going on here... and figure out how to get the new rubber to wear evenly --- it MUST be possible.
Dealing with height & alignment adjustment is new territory for me. Am sure to hit some roadblocks where help will be both needed & appreciated. Will start from beginning so leading comments and pics will be familiar if you visited prior "bye-bye 245" thread...
Old front tires on car a few months ago. Insides going... surprise-surprise!
http://forums.pelicanparts.com/uploa...1415200905.jpg
Left front at time of replacement. Tire here is still holding air. Is also insanely out of balance.
http://forums.pelicanparts.com/uploa...1415200974.jpg
Looking at one of rears. Both sides look the same. Best wear I've ever seen from rears but for being slightly over-inflated and sure... inside wearing.
http://forums.pelicanparts.com/uploa...1415201019.jpg
After loading new tires, I checked front and rear toe with "C" method. Front = toe OUT total 1/8". Rear = toe IN total 1/16". Am not pothole-diver or run-over-curb'r so toe settings should be according to last shop's adjustment. I saw their latest & greatest alignment equip. What I missed seeing was monkey running equipment & wrenches. Can I do better? Sure f'in hope so.
Today...
Have Ray Scruggs booklet so will be referring to that for alignment. Before aligning, am setting height & rake with 30 lbs front and 32 rear tire pressure. Just measured fender heights before diving in. Front side-to-side are = . Rear are = too. (Monkey got that right.) Starting at front... have just turned adjustment 2 rotations clockwise (when looking up from ground) on both sides... No problem here.
http://forums.pelicanparts.com/uploa...1415201182.jpg
Rear end adjustment... not going smoothly. Problem = forward bolts on spring plates on both sides are spinning. Rear bolts both loosen as they should. What am I missing here? Space is too tight to get standard wrench in. Is there special wrench? Plates have moved but not evenly on both sides---left side did not move same as right side (shown below.) Forward bolts remain snug but not tight. Seems whomever set this last walked away from them just snug. Or, both front nuts went loose by themselves. Whatever the case, this needs to be corrected.
http://forums.pelicanparts.com/uploa...1415201383.jpg
Rear (24 mm) nuts on both sides = damm tight. 3' cheater in use.
http://forums.pelicanparts.com/uploa...1415201437.jpg
Before and after...
http://forums.pelicanparts.com/uploa...1415202034.jpg
http://forums.pelicanparts.com/uploa...1415202068.jpg
Hard, tight ride... works for me. '74 Carrera I drove for many years was lower than this. So 'sticky brick' is familiar. Problem with '74 low rider was relentlessly having to watch every inch of road... in other words, 1 manhole a little high = problem. Don't want to drive like that now. So, am going a bit higher here. Will test drive this height a few days before doing alignment. Looking over Scruggs booklet, just noticed he advises sway bars disconnect when leveling car. (TY Ian for assistance with Scruggs.)
Questions:
Resolved: Forward nut & bolt on spring plate... how is bolt kept stationary?
Resolved: How is fender rolled without screwing up paint?
Driven97 11-05-2014 08:42 AM
1/8" of toe out front is on the high side, imho. Ususally toe out causes inside edge wear, toe in outside edge wear, assuming minimal camber. Probably also made the car wander a bit on the freeway? If you still have your old tires, check them for feathering. Toe related wear leaves "sharp" edges in one direction, and "soft" edges in the other.
http://edge.tireguides.com/images/tips/feathering.jpg
That's obviously exaggerated, but you can feel the difference if you run your hand across the tread.
Adjusting your front toe to a sixteenth in or so should greatly reduce your wear and still have the car track nice and straight on the freeway. The cars have like no weight up front so they're kind to front tires in normal driving.
Rear wear looks really good, if you're happy with the way the car drives and handles I wouldn't futz with the rear alignment. Lowering may tweak it a bit, but it's such a PITA to align things back there hold off unless it's really bad.
For the rear our host sells a thin wrench for those spring plate bolts. I forget which is which, but one is a cam and the other a lock. Loosen both, turn the cam (from the narrow gap) to get the angle you want, and lock them both down.
Also, it's best practice to measure heights / alignment with the car loaded to it's intended use. If you normally drive solo, add your weight to the driver's seat. Also consider a half tank of gas, as at 6lb per gallon there's a 126 lb difference on the front end between an empty and full tank.
I've never tried to roll a fender, but I've heard using a heat gun to gently warm the paint then going a fraction of a bend at a time is the best bet to keep paint happy. My 225s fit up front no problem, and they're really wide for their rated width - are you getting contact with 205s?
Discseven 11-05-2014 09:34 AM
Scruggs suggests 1/8" TOE IN at front for street. Don't have old tires. 1/16 toe at rear... I may indeed leave alone---but will check toe again if height stays down... plus will load as you mentioned + 1/2 tank gas. Completely forgot about loading. Wrench... wondering if I can get it local (as it's on "want it right now" list.) Your heat gun comment... sounds reasonable. Don't want to fix height & alignment only to f up paint. Perhaps will put "roll" in paint & body forum. Was thinking about 225s. Decided to go with sizes I already know. TY for input Matt.
Is spring plate bolt head 24 mm like nuts?
Driven97 11-05-2014 09:47 AM
This is the one our host sells. It's 24mm and 36mm.
I bought it and honestly the metal is a little soft - it works, but I'm not super confident in it. I'm sure Google could come up with other options in various price ranges.
Discseven 11-05-2014 03:49 PM
Matt... TY for wrench link. Do you know if the "behind the plate" size is 24 mm? I plan to stop a Snap On truck tomorrow to see if they have.
Oh Haha 11-05-2014 04:57 PM
24 mm wrench can be found at a bicycle shop. A bigger shop would have flat wrenches in many sizes.
Discseven 11-05-2014 07:09 PM
Thanks Wayne.... bike shop it is.
Arne2 11-05-2014 08:36 PM
I have a set of these from HF - all the sizes you might need. Besides the rear adjusters, I've also used one on the oil pressure sender.
http://www.harborfreight.com/15-piece-metric-service-wrench-set-93668.html
Discseven 11-06-2014 04:15 AM
15 Piece Metric Service Wrench Set
Hey Arne... TY for HF flat wrench link. More than I wanted to spend but might go this route as am having erratic oil level readings---been told to clean sender contacts.
will hung 11-06-2014 04:50 AM
In regards to rolling the fenders. Rent a fender roller. You can do it with other cylinders, but a fender roller will give you the most control so that you can take your time, and decrease the chances of cracking your paint.
First, attache the roller to your hub so that it's ready to go, then get out your heat gun...
With a heat gun, run it back and forth over your fender, but not just on the outside When I rolled mine, I ran the heat gun along the outside for a full sweep, then back aiming straight up at the lip a full sweep, then back again aiming at the inside, then I swept back from outside the fender aiming straight down at the fender flair. I kept doing this until the entire fender had a nice even temperature and was fairly hot to the touch.
I then set up my fender roller and aimed to roll only about a 2" length of the fender and only intended to bend the lip a little. I then concentrated my heat gun to that area, overlapping about an inch or two beyond my 2" length, but also sweeping the heat gun to maintain heat in the fender.
I crept along the fender in 2" increments until I was at the end. And then repeated rolling the lip a little more. I think I did the entire roll in about 4 or 5 passes, just a little at a time.
The key is lots of heat in the paint to make it more pliable and rolling the fender in small increments so that the paint isn't forced to do too much at one time.
Discseven 11-06-2014 06:54 AM
Just looked at few vids on subject. Rollers as you mention Will. Baseball bats. Pipes wrapped in tape. Now I get. Thanks for rental suggestion. Am looking into that.
Driven97 11-06-2014 07:07 AM
IIRC the Eastwood roller doesn't fit the Porsche bolt pattern. Someone made an adapted version that fits and was renting it out a few years ago, not sure if they still are.
NoYouRelax 11-06-2014 07:18 AM
Karl,
I think you and I were doing the same Targa lowering project this week with the same problem, that spinning front bolt. I ended up buying that thin wrench set from HFT but could not make it work.....I had no idea the front bolt was 24 MM. As you know it is a blind effort. I will attempt this again shortly with more knowledge now.
BTW your final stance looks great. Do you have wheel spacers on the front or rear wheels?
will hung 11-06-2014 01:06 PM
I used this website's service to rent a roller.
RollYourFender.Com - Home - Fast, Easy, & Affordable Professional Fender Lip Roller Rental
Their service was great and you can rent the Porsche bolt pattern adapter. They also include a heat gun.
Discseven 11-06-2014 05:10 PM
Good heads up on IIRC Matt. TY
Discseven 11-06-2014 05:38 PM
Originally Posted by NoYouRelax (Post 8341154)
Karl,
Been waiting to see if anyone else had a front spinner. Feel better now that I know am not alone --- TY NOYOU! Yaya... we're on same page as it were. TY on stance. No spacers. 8" fronts... 9" rears. Was thinking about spacers on rear... just haven't gotten to it yet. So many other things to deal with. Sure you can relate.
Checked local bike places for 24 mm flat wrench and they had them... just didn't want to sell them. Tried some tool places too and... nothing. Finally decided to go to ACE and put on creative hat. Was thinking that back side might grab once nut was tight enough so... might be a matter of keeping bolt from initially spinning. Got this narrow jaw vice grip...
http://forums.pelicanparts.com/uploa...1415323044.jpg
F'in thing worked.
Do have new problems on hand...
1) Can't even out my spring plates. Want to adjust side that rides lower than the other but can't get spring plate to move down.
2) Lots of creaking coming from back now when suspension travels.
Checked toe both front and back and more toe OUT resulted from lowering. Will post pics & notes tomorrow morning on today's alignment progress.
Discseven 11-06-2014 05:46 PM
$75 not including shipping. Not bad. TY for link Will. Am curious... have you done both a bat and this gizmo roll? Bottom line... can you compare them for us?
ClickClickBoom 11-06-2014 06:32 PM
Corner balance! Now that you jacked with the ride height, the corners now must be balanced or it will possibly be wiggly, and your tires will wear like erasers.
Discseven 11-07-2014 06:07 AM
Originally Posted by ClickClickBoom (Post 8342290)
...corners now must be balanced or it will possibly be wiggly, and your tires will wear like erasers.
Good one BOOM! I've heard of "corner balancing." Will see if that's in Scruggs booklet. TY for notice.
Oh Haha 11-07-2014 06:25 AM
The best way to corner balance is to have a shop that is familiar with 911s do it. If that is not an option the "tripod" method can be used at home to get it pretty close.
Oh Haha 11-07-2014 06:29 AM
I found a good thread http://forums.pelicanparts.com/porsche-911-technical-forum/213694-home-ride-height-corner-balance-success-story.htmlon the tripod method.
Discseven 11-07-2014 07:05 AM
Yesterday... did front toe adjustment day. (Am not going to adjust caster---it's fine the way it is. Camber I have discovered is fully adjusted meaning top of struts are fully out from center of car. So where it is now is likely where it will stay. Have heard about places that will adjust the spindle but I want to run these tires and see what results are had from toe only adjustment set per Scruggs specs.)
Here's progression of measurements... starting with where I found front toe... after lowering, and where I brought it to (just inside 1/8" toe IN.)
http://forums.pelicanparts.com/uploa...1415372060.jpg
Before dealing with rear camber then toe, I have spring plate problem to deal with---want to swing the spring plate down on passenger's side but can't get it to move. Also have creaking noise from rear when suspension travels. Help with these challenges would be appreciated.
NOYOUrelax... where are you at with your project?
will hung 11-07-2014 07:09 AM
Unfortunately, no, I have not used the bat method. But after watching videos of people using bats, if the car was a race car or if I was getting ready to paint it, I'd have no problem using a bat.
Your original question was how to roll your fenders without cracking the paint. In my opinion, your best bet is to use a real fender roller. When you use one, they are really slick. The amount of control you have not only in how much you are rolling the fender lip over but how far you are rolling it is incredible.
Like I said in my earlier post, one of the keys to not cracking the paint is rolling the fender in small increments. Not just along the arch of the fender but also in not just totally rolling the lip in one pass. You need to make several passes rolling the fender just a little each pass. The fender roller tensions so easily that keeping the pressure of each pass uniform is a piece of cake. I probably used 6 or 7 passes to slowly roll my fender. Each pass I rolled the lip a little tighter to the fender.
Discseven 11-07-2014 07:25 AM
Will... TY for notes. Q: did you compress the hanging lip entirely up against the inside of the fender so the roll is now flat? Any concern with rusting?
Discseven 11-07-2014 07:32 AM
Originally Posted by Oh Haha (Post 8342810)
Craig did good on that write up... TY WAYNE. Increasingly apparent how much more knowledge I need to gain. Measuring off fenders does seem dubious. Will get into more accurate measures after preliminary adjustments.
will hung 11-07-2014 07:51 AM
Yeah, I rolled to the fender.
Before starting, I scrubbed the inside of my fenders to make sure that no residual dirt or grime was going to get trapped in the fender. I then rolled it onto itself. Then I ran a bead of silicone between the old fender lip and fender.
Between that and the galvanized front fenders, I'm not too concern about rust.
Discseven 11-07-2014 12:39 PM
Excellent... TY For info Will. Post some pics if you're inclined.
Discseven 11-10-2014 09:39 AM
Am returning to see what I can do about moving my stuck spring plate.
Bob930slant 11-11-2014 01:34 PM
here is a pic of the wrench i made. 18 guage flat steel, cut to 36mm on one end and 24 mm on the other end. a little time with the grinder and in 15 minutes you will have your own custom rear suspension wrench for about $1.
http://forums.pelicanparts.com/uploa...1415741447.jpg
Discseven 11-11-2014 02:10 PM
$1.... Way to go Bob. Love it! TY for inspiration.
Is back side of those 24 mm's on spring plate 24 or 36?
Discseven 11-11-2014 02:20 PM
Did Scruggs corner balance test today. Pulled slightly to right. Given right rear spring plate being lower than left, this should have put more weight on the left rear and right front... causing pull to left. Something's not right here.
Bob930slant 11-11-2014 03:18 PM
bolt head on lock nut is 24 and the head of the ecentric is 36. here is a pic from the forum tech article that shows both sides
http://forums.pelicanparts.com/uploa...1415747727.jpg
midnight911 11-11-2014 10:48 PM
very nice.
way better than my ground down craftsman.
Discseven 11-12-2014 04:38 AM
Excellent reference BOB. TY
Discseven 11-12-2014 04:40 AM
BOB... what did you use to cut 18 gauge?
DRACO A5OG 11-12-2014 06:49 AM
You can also grind down a cheapo 24 MM wrench.
Going that low in front you should consider a bump steer kit.
Discseven 11-12-2014 08:40 AM
Grind thick wrench down... damm fine idea Jim. TY
Suspension = all new to me so on big learning curve here. Bump steer. Heard of it but going to ding into some vids to get better acquainted. Ahhhh... I get it.
Investigating Bump Steer - YouTube
Longacre Bumpsteer Gauge Demo - YouTube (TY Sherwood)
Discseven 11-12-2014 08:44 AM
Am still challenged by uneven spring plates. Been trying to move lower swung spring plate up and it's not happening. Do I have to disconnect everything from it in order for it to move?
Oh Haha 11-12-2014 09:42 AM
tfhstuy reported as spam:mad:
Discseven 11-14-2014 02:39 PM
Spent afternoon attempting to raise right side spring plate slightly... finally said screw it. Am going to move on to corner balancing--perhaps spring plates are already in correct position! Preliminary Scruggs road test suggests more weight being on L front and R rear. Am going to use measure method to check CB.
http://forums.pelicanparts.com/uploa...1416004580.jpg
