Question hot and cold air distribution levers will not stay in place
The hot and cold air distribution levers on my 88 cab will not stay in place after adjusted. If I push either lever all the way left or right they will go back to near center once I let go of the lever. Any suggestions...adjusted, clean cables...?
1988 911 Cab; 2012 997 TTS; 1999 Jeep Wrangler; 1970 Honda CL100; 1972 Kawasaki H2; 1972 Suzuki TM400; 1973 Kawasaki F11-250; 2007 Ducati SportClassic 1000; 2013 KTM 350EXC
Old 11-08-2014, 10:56 AM
wacko's Avatar
I had same problem. The cable was kinked so it wasn't travelling through the housing but just bending when lever adjusted so it would just spring back.
I was able to straighten it and adjust so it works again. It was a pain as I did it under the dash.
I believe it happens from people forcing the lever further than it needs to go.
Old 11-08-2014, 11:02 AM
Designer King
Paulporsche's Avatar
I don't know if the system is the same on late S or SC models, but if it is, this can be due to incorrect adjustment of the control wire, the arms, or the flaps inside, or possibly the foam gaskets on the flaps inside the vent tubes breaking up.
Make sure everything is aligned properly at points marked A. Make sure the flaps inside these points are in good shape.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-08-2014, 11:24 AM
wwest's Avatar
WD40 sprayed inside the sleeve from both ends while moving he adjustment full travel often helps. Same with heater flapper control cables.
Old 11-08-2014, 11:33 AM
