TheSt|G's Avatar
Lowered the idle, now I get engine clunking?
I have an '85 3.2 with ~95,000 on the clock. I recently installed a Steve Wong chip and modified the ECU to the 4k specs. Being someone who generally takes things in slow steps, I left the idle adjustment alone until I was sure everything else was happy.
Last Saturday I decided to finally lower the idle after getting home from a long drive. I dialed it down to ~900rpm from 1100-1200rpm, and she seemed to settle out. I had my fiance pull the 911 into the garage so I could listen to the changes on the way in, but her foot slipped and the car stalled.
Here is where it gets weird. She goes to restart it and nothing(never had an issue ever). Car cranks once like it has a dead battery but gets no further. She gets out and we start to push it in. I decide to give it another shot after a bit of pushing, and low and behold she fires right up. Downside is, now she is making quite a bit of clunking. I pull into the garage and turn her off.
Sunday I head out to the garage again and fire her up. Idle bounces up, down, up, down, up, down, and then settles. Engine is making a fair bit of clunking at idle. Slight tap of the gas(2k-3k rpms) seems to make it go away?
Any thoughts?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 11-10-2014, 05:35 AM
TheSt|G's Avatar
Looks like I might not have had the jumper engaged completely, will play around with this tonight and report back.
Old 11-10-2014, 06:46 AM
T77911S's Avatar
the idle is not adjustable.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-10-2014, 07:15 AM
TheSt|G's Avatar
So what is this?
911Chips.com - Motronic DME Update
Old 11-10-2014, 07:30 AM
You should also check your idle position switch.
Rick
88 Cab
TheSt|G's Avatar
Would that be impacted by my adjustment of the screw without properly jumping the pins? I only ask because I'm hesitant to spread the problem if I just need to adjust it back slightly.
Old 11-10-2014, 07:37 AM
Originally Posted by TheSt|G View Post
What you are setting is the base idle speed with with the idle control disabled. This is so the DME is adjusting the idle up and down with small amounts of input from the idle air control valve around what it should be.
The 2k 4k just refers to the amount of memory for the program in the chip.
Rick
88 Cab
Old 11-10-2014, 07:39 AM
If your idle was 1200 rpm either the engine was cold or the idle switch was open.
Edit: or your idle air control is stuck
Rick
88 Cab
Old 11-10-2014, 07:45 AM
TheSt|G's Avatar
Right. Is that not something I need to do post ECU modification?
Old 11-10-2014, 07:53 AM
Does this mean the engine rotated until it hit a compression stroke and the lights went out?
Battery terminals?
Rick
88 Cab
Old 11-10-2014, 07:54 AM
It does not have anything to do with whether the idle is adjustable or not which is what the response was.
Rick
88 Cab
Old 11-10-2014, 07:55 AM
TheSt|G's Avatar
Battery terminals?
No, it means it acted as if they was almost no power to crank the starter. Lights and everything else are fine, battery is clearly charged. I would ignore this aspect for now as it hasn't happened since.
Ah, forgive my ignorance on this then. Basically, all I'm trying to do is set the idle back to where it should be post ECU modding as per those instructions. I now believe I didn't have the jumper properly engaged, which means the electronic idle controls would be fighting my manual adjustments correct?
Old 11-10-2014, 08:08 AM
ejp ejp is offline
ejp's Avatar
This is incorrect - the link that you (TheSt|g) posted from Steve Wong does indeed show how to adjust your idle (and I've done this on my 3.2).
I can't say for sure whether or not your idle needs to be adjusted, but the idle on the 3.2 Carrera is indeed adjustable. When I first tried to adjust my idle, it was initially too low, and once the car heated up, the idle on my car would bounce in the same way that you described in your car (except that there was no clunking noise from my car). In my experience, the idle adjustment was somewhat finicky to get right, you may want to keep working at it.
-Ethan
Old 11-10-2014, 08:18 AM
T77911S's Avatar
its not suppose to be messed with. if the idle changes on the car, something else is wrong.
RACE CAR:: sold
Old 11-10-2014, 09:18 AM
TheSt|G's Avatar
So you are saying that Steve W is wrong on his chips and the idle shouldn't be touched after modifying the ECU?
Old 11-10-2014, 09:48 AM
wrxnofx's Avatar
What he means here is that, when the throttle is at idle position, there is a switch on the back of the black rubber intake elbow that is supposed to get engaged that tells the DME to run at the idle program. If you open the throttle 1 or 2 mm, the idle switch disengages and, per Bentley, automatically causes the rpm to jump up by 500 rpm (and advances the timing).
You can test whether or not the idle switch is working when the engine is shut off by checking continuity. PM me if you need the info from Bentley on how to do this. You can hear the switch click if your garage is quiet enough.
Presumably T77911S hasn't installed a Steve Wong chip. Per Steve's instructions, the idle changed due to the chip installation, and you must adjust the base idle back down to 850 or 880 rpm.
To do this, get the car up to operating temperature (I would expect this is to make sure that the DME is running in the proper mode and not in some warmup mode). Remove the back fuse panel cover and stick a jumper into the necessary holes in the test port. I use a paper clip bent over on itself in order to create the necessary friction so it sticks in the holes.
When you insert the jumper, the DME no longer uses input from the ICV (Idle Control Valve), so you're not trying to hit a moving target. To adjust the idle down you'll have to screw the base idle screw clockwise. There may be a yellow "tamper proof" cap over the adjustment screw that you'll have to remove (i.e. break). A new one is $1.03 from your friendly neighborhood Porsche dealership (ask me how I know).
No disrespect meant to anyone, but the 1 sentence responses are often really cryptic to understand and just serve to make me more confused. Maybe it's just me. I can't typically solve a complex problem in 1 sentence, but no one ever accused me of being the smartest guy in the room.
If you can't get this resolved then I'd contact Steve. He seems to be really helpful on here, especially when it comes to his own products.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 11-10-2014, 12:52 PM
Here is a dumb question. DId you bolt the ECU back down? We had a friend make the chip change, and then not bolt the ECU back down under the driver's seat, and the car started doing weird things. It turns out that the box is grounded via the mounting bolts.
Just an idea.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-10-2014, 12:57 PM
TheSt|G's Avatar
Hugely helpful response. Over communication is always best.
Just an idea.
I can double check it, but it seems unlikely that it happened to get loose at the same time as I adjusted the idle screw.
Old 11-10-2014, 01:27 PM
TheSt|G's Avatar
So as an update:
I adjusted the idle properly and it seems to settle into the ~proper range once cold start is over. Not too concerned about hitting the exact figure. What does concern me is that the engine still has that clunky rattle, but only at that lower idle. As soon as I give it a bit of gas it completely goes away and she is smooth.
Old 11-10-2014, 04:09 PM
Call 911
dkirk's Avatar
Do you think the rattle could be in the drivetrain (transmission, spring centered clutch disc) that wasn't noticeable when engine idled at the higher speed? I'd suggest putting in 4th or 5th gear with car stationary, letting out the clutch slowly to the engagement point, and see if rattle goes away.
Dave Kirk
My Porsche restoreth my soul.
Old 11-10-2014, 04:32 PM
