Lowered the idle, now I get engine clunking?
I have an '85 3.2 with ~95,000 on the clock. I recently installed a Steve Wong chip and modified the ECU to the 4k specs. Being someone who generally takes things in slow steps, I left the idle adjustment alone until I was sure everything else was happy.
Last Saturday I decided to finally lower the idle after getting home from a long drive. I dialed it down to ~900rpm from 1100-1200rpm, and she seemed to settle out. I had my fiance pull the 911 into the garage so I could listen to the changes on the way in, but her foot slipped and the car stalled. Here is where it gets weird. She goes to restart it and nothing(never had an issue ever). Car cranks once like it has a dead battery but gets no further. She gets out and we start to push it in. I decide to give it another shot after a bit of pushing, and low and behold she fires right up. Downside is, now she is making quite a bit of clunking. I pull into the garage and turn her off. Sunday I head out to the garage again and fire her up. Idle bounces up, down, up, down, up, down, and then settles. Engine is making a fair bit of clunking at idle. Slight tap of the gas(2k-3k rpms) seems to make it go away? Any thoughts?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Looks like I might not have had the jumper engaged completely, will play around with this tonight and report back.
the idle is not adjustable.
You should also check your idle position switch.
Rick 88 Cab |
Would that be impacted by my adjustment of the screw without properly jumping the pins? I only ask because I'm hesitant to spread the problem if I just need to adjust it back slightly.
The 2k 4k just refers to the amount of memory for the program in the chip.
Rick 88 Cab |
If your idle was 1200 rpm either the engine was cold or the idle switch was open.
Edit: or your idle air control is stuck
Rick 88 Cab Last edited by rick-l; 11-10-2014 at 07:49 AM.. |
Does this mean the engine rotated until it hit a compression stroke and the lights went out?
Battery terminals?
Rick 88 Cab |
It does not have anything to do with whether the idle is adjustable or not which is what the response was.
Rick 88 Cab |
Ah, forgive my ignorance on this then. Basically, all I'm trying to do is set the idle back to where it should be post ECU modding as per those instructions. I now believe I didn't have the jumper properly engaged, which means the electronic idle controls would be fighting my manual adjustments correct?
This is incorrect - the link that you (TheSt|g) posted from Steve Wong does indeed show how to adjust your idle (and I've done this on my 3.2).
I can't say for sure whether or not your idle needs to be adjusted, but the idle on the 3.2 Carrera is indeed adjustable. When I first tried to adjust my idle, it was initially too low, and once the car heated up, the idle on my car would bounce in the same way that you described in your car (except that there was no clunking noise from my car). In my experience, the idle adjustment was somewhat finicky to get right, you may want to keep working at it.
-Ethan |
its not suppose to be messed with. if the idle changes on the car, something else is wrong.
So you are saying that Steve W is wrong on his chips and the idle shouldn't be touched after modifying the ECU?
You can test whether or not the idle switch is working when the engine is shut off by checking continuity. PM me if you need the info from Bentley on how to do this. You can hear the switch click if your garage is quiet enough. Quote:
To do this, get the car up to operating temperature (I would expect this is to make sure that the DME is running in the proper mode and not in some warmup mode). Remove the back fuse panel cover and stick a jumper into the necessary holes in the test port. I use a paper clip bent over on itself in order to create the necessary friction so it sticks in the holes. When you insert the jumper, the DME no longer uses input from the ICV (Idle Control Valve), so you're not trying to hit a moving target. To adjust the idle down you'll have to screw the base idle screw clockwise. There may be a yellow "tamper proof" cap over the adjustment screw that you'll have to remove (i.e. break). A new one is $1.03 from your friendly neighborhood Porsche dealership (ask me how I know). No disrespect meant to anyone, but the 1 sentence responses are often really cryptic to understand and just serve to make me more confused. Maybe it's just me. I can't typically solve a complex problem in 1 sentence, but no one ever accused me of being the smartest guy in the room. If you can't get this resolved then I'd contact Steve. He seems to be really helpful on here, especially when it comes to his own products.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Here is a dumb question. DId you bolt the ECU back down? We had a friend make the chip change, and then not bolt the ECU back down under the driver's seat, and the car started doing weird things. It turns out that the box is grounded via the mounting bolts.
Just an idea.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
![]() Quote:
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs Last edited by TheSt|G; 11-10-2014 at 01:48 PM.. |
So as an update:
I adjusted the idle properly and it seems to settle into the ~proper range once cold start is over. Not too concerned about hitting the exact figure. What does concern me is that the engine still has that clunky rattle, but only at that lower idle. As soon as I give it a bit of gas it completely goes away and she is smooth.
Call 911
Do you think the rattle could be in the drivetrain (transmission, spring centered clutch disc) that wasn't noticeable when engine idled at the higher speed? I'd suggest putting in 4th or 5th gear with car stationary, letting out the clutch slowly to the engagement point, and see if rattle goes away.
Dave Kirk My Porsche restoreth my soul. |
