Tachometer dead after engine drop (?)
Finally got the engine running again after my first engine drop but now the tach is dead. I seemed to be getting a signal when I was cranking the engine to build oil pressure prior to starting for the first time, but now that she has fired up - no tach.
Any ideas where to start trouble shooting?
1976 911S, sleeping for 13 years, back to life in 2013! |
ROW '78 911 Targa
Signal wire connected at the white "T"connector below the CDI?
Wire comes from points to T connector with red wire sending tach signal to tach.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 11-09-2014 at 06:52 PM.. |
Ah ha. Thanks for the tip on where to find the signal wire. It is connected, but it also appears to be loosely wrapped with electrical tape at the "t". I was having trouble getting the engine to fire and realized that I had the timing 180deg out of phase. I pulled the distributor without disconnecting the signal wire, and perhaps I've stressed the connection.
I'd mess with it now, but it's late, my kid's bedroom is above the garage, and the engine is really loud! I'll check it tomorrow morning, but if anyone has other ideas, I'm still open. Thanks
Oh well, messed with the white "t" wiring and fired up the engine but no dice, still no tach.
A couple notes: 1) Car has blue Perma-tune unit, this was an upgrade long ago by a PO; 2) the tach gives a little blip when the engine initially fires up, but then no life afterward. Any leads will be of help. Thanks
Can you test the tach in another car? Tach could be bad.
Also check the ground wires on the back of the tach, be sure they are clean. And fully charge the battery. I've seen tachs not work if battery is low.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
I can't test the tach in another car. It was working fine last year prior to the engine drop. The battery is brand new, but it did get a good workout as I cranked the engine for a total of about 2-3 minutes (30 second intervals) to prime the engine with oil, so maybe a low battery.
Engine fires up instantaneously, so I'm not noticing any weakness in the battery. The only good news I have so far is the instantaneous start. The engine used to take quite a bit of finessing to get it to start and idle smoothly when cold. Now I have a powerful start-up, just no tach :-(
ROW '78 911 Targa
Just to clarify my earlier post.
The red wire in the T connector is the switched power to the CDI on an original 3 wire CDI setup. The other wire with the red wire in the connector should be the tach signal wire from the points on the ''73.5-'77 ignition wiring.
Here's my connections. Sorry about the upside-down pix
Still dead.
What next? Check Voltages? How?
ROW '78 911 Targa
Show us what is under the tape where the white T connector is.
Pulled the tape off. The plastic insulation was broken, but the wire is intact and connected
Drove about 35 miles this weekend.
No tach, but a distinct blip on the tach needle at start up and power off. So the tach appears to get something. but the needle is dead as a doornail when the engine is running. I guess my next step is to pull the tach out. Any tricks I need to be aware of, I don't want to damage anything (cosmetically, electrically, or mechanically)
