Member 911 Anonymous
DRACO A5OG's Avatar
"clunk" like a rattling metal trash cans?
Take a video clip of it and post it.
'85 Carrera Targa
PCA/POC
Old 11-10-2014, 05:10 PM
scarceller's Avatar
Can you tell what area the clunk is from?
I agree with Draco, try to do a video or sound recording of the problem.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-10-2014, 05:21 PM
TheSt|G's Avatar
Agreed that a recording makes sense, I'll see what I can do tonight. Describing a sound in text is always pretty worthless.
As for location, its pretty hard to pin point. I used my stethoscope on each of the intake runners and just got the sound of cold tappy valves, so it doesn't appear to be coming from one of the cylinders specifically.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 11-11-2014, 05:19 AM
What would happen if you removed the Wong chip and put the original back in? Or are we past that point, due to the 4k mod?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-11-2014, 06:43 AM
scarceller's Avatar
If the DME was 2K with the 2K chip and it was Modified for the 4K chip you can't just put in the 2K chip. You need to undo the modification. Or better yet obtain a factory 4K chip if possible, if you have a SW 4K chip and a factory 4K chip you can swap them whenever you like.
This is exactly why when I convert DMEs to 8K 1989 chip specs with the 28pin chip I always deliver the DME with the factory 8K chip and then any other of my perf chips of choice.
But I doubt the SW 4K chip is the source of the clunking issue. The SW chips are well done and are a good product. Not sure why you want to go back to a factory chip? Although I agree it's a very nice option to be able to go back to factory chip.
Sal
1964 356SC (SOLD)
Old 11-11-2014, 06:52 AM
TheSt|G's Avatar
Past that point unless I solder the board again. Frankly, I'd rather not as those ECU case tabs only have so many flexes in them before they break off. I also doubt it is the chip as I've had it in for a few months already with no issue.
Old 11-11-2014, 07:14 AM
scarceller's Avatar
To save the tabs on the case I don't crimp them back, I simply use a large tie wrap to hold the case in place. This way if you open the case again you just cut the tie-wrap. Or better yet get a long Velcro strap.
Sal
1964 356SC (SOLD)
Old 11-11-2014, 07:32 AM
TheSt|G's Avatar
Not a bad idea. Either way though, I suspect it isn't related at this time.
Old 11-11-2014, 08:43 AM
How old is your battery?
Old 11-11-2014, 10:44 AM
TheSt|G's Avatar
6 Months.
Old 11-11-2014, 11:27 AM
If it is running well enough to drive, you can bring it by this evening and we could all brainstorm on it. I have the Bentley and the Pelican Forum at hand.
Old 11-11-2014, 11:56 AM
TheSt|G's Avatar
It is an excellent offer, but I'm a bit hesitant to drive it around until I have some idea of where the clunking is coming from. The fact it goes away with any amount of revs seems encouraging though.
Old 11-11-2014, 12:15 PM
wayner's Avatar
Something similar happened with a friends car of a different brand.
He stalled it by slipping off the clutch by accident. Then, it wouldn't turn over after using the starter motor
Eventually we push started it and it had an ungodly clatter.
It turned out to be the clutch. Apparently when he stalled it he sheered the rivets that hold the clutch plates together. It was old and just suddenly failed when his foot slipped off the clutch and it violently engaged.
No other damage, just a blown clutch pack.
If that is the situation with yours it may be that at speed it sits properly but moved around without the centrifugal force from turning higher RPMs?
SOLD - 914 wide body hot rod
Old 11-11-2014, 01:45 PM
TheSt|G's Avatar
Interesting thought, I'll get the stethoscope and poke around down there. I didn't notice anything weird about the clutch when I pulled it around into the garage, but frankly I was focusing on the engine.
Old 11-11-2014, 01:51 PM
Any updates? Do we need to get a group to come by and analyze the situation?
Old 11-17-2014, 07:23 AM
DRACO A5OG's Avatar
You can remove the ac belt and listen then fan belt and listen ( but for a a minute or two no longer ).
CCM, he will come around eventually " you can lead a horse..."
'85 Carrera Targa
PCA/POC
Old 11-17-2014, 07:43 AM
