Corroded 996 from the NE What to use?
Just bought a 996 TT from RI. The undercarriage looks like it has been sitting in salt brine for a few years. Everything is corroded from the suspension and discs on down. Has anyone found a treatment that works for this nasty crust.
Thank you |
A bunch of elbow grease along with brass brushes. For the nastiest stuff - clean and refinish or replace.
Kurt |
Doing it right? Strip, treat, replace, refinish.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Flood car or just winter road rash?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Project Addicted
Wire brush and POR15. Follow instructions and it will protect for a long time and none of that crust will come back.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
buy an angle grinder with a wire wheel, remove every bit of rust and apply por15.
sell
What KNS said plus look up a product called aluminum soap.
Dynamite.
Johnny Walker's probably right, although you may want to try the following:
1. wire wheel the worst of it off (use a good dust mask) 2. spray on phosphoric acid (available in gallon jugs at Home Depot) 3. after the acid has eaten away the rust, rinse it with denatured alcohol 4. give it 2 coats of MasterSeries silver primer 5. top off with Por 15 or some other finish coat. If it will be exposed to light, use something other than Por 15. Messy job, especially if you're working upside-down. Have fun.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
