A/C Charge.. Horse's Mouth
Apparently in '88 the compressor displacement was high enough to fill the R/D accumulator volume with a full HEAT load and even with the engine idling.
Damm simplified way to check refrigerant. Am curious why all R/D's don't have the ball if that's how easy it is.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Not so sure it will work at idle with your lower displacement volume Sanden even were you to use a standard fill. |
Banned
Karl, notice that is Porsche's suggestion to eyeball verify that there is a minimum amount of refrigerant in the system between service intervals with a stock system (doesn't note which variety of refrigerant, however - was r12 still being used by the factory in 1988?), of course, you can bet yer bowels that a quick feel of the vent air temp will give you the exact same information.
My '88 Special Edition Carrera was converted to R-134a years ago. |
Banned
The state of charge is easily verified with an a/c gauge set and your "not so" is indicative of your lack of automotive a/c experience (sure doesn't keep you from crowing about the subject, however). |
"Check the refrigerant level at least once a year because the fluid diminishes gradually during operation".
So, why does the fluid/gas disappear, into the atmosphere? AND Why during operation? |
UnRegistered User
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Billy,
Oh. Really. So does that mean I don't have to change the air in my tires every month? |
When I first tried to charge my system I used the floating ball on the Receiver-dryer method. With a fully stock R-12 system I kept adding R-12 until the ball floated like described in the instructions. Then I went and looked at the gauges and the system was way overcharged. The high side was up in the 330 PSI range on a 80 degree day. I had a AC technician friend come over and we set the charge to the proper level via the gauges and it was cold again. Well as cold as the stock system can get.
Now I just totally ignore the ball. One of these days when I have to hook up the gauges again I will think to check the ball with a good pressure and temp setup. I am curious what the ball will do. With winter weather here and my AC system working normally it will not be checkd anytime soon.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
"...system was way overcharged.....330 PSI...."
From what source did you determine that constituted an overcharge ...?? |
The pressure and temperature charts and my friend and mentors 25 years of AC service. The OAT was in the mid 80s.
Will, when your 911 AC is charged to level you prefer, what high pressure do you run (and at what rpm)?
