logician's Avatar
Question Sprocket parallelism
Hi,
Has anyone out there checked chain sprocket parallelism? I'd like to check the parallelism in my 930 engine, because I suspect a previous mechanic may have mixed up the shims. I've read the procedure and it looks pretty sensitive to errors. If you've got any words of wisdom on the procedure, I'd appreciate hearing from you.
Thanks!
-Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011
ArtOfRoadRacing@gmail.com
SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11
Old 10-11-2002, 12:18 AM
Irrationally exuberant
ChrisBennet's Avatar
I've done it and you're right, it is sensitive to errors. I found it necessary to have an extra set of hands to hold the straight edge. Stomski Racing makes a tool so you can do it a little easier.
-Chris
Old 10-11-2002, 01:01 AM
Cool
I believe Pelican has a good inexpensive one..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2002, 05:35 AM
Ron,
I couldn't find it on Pelican. Here is the Stomski Racing one.
-Chris
Old 10-11-2002, 05:58 AM
Cool
thanks Chris..I gotta buy one before I open her up..................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2002, 06:25 AM
Navin Johnson
TimT's Avatar
Ron, your rebuilding it?
'69 911 GT-5
'75 914 GT-3
and others
Old 10-11-2002, 02:50 PM
Cool
No Tim..not rebuilding...Rudtner just did the final smog on the '77..and I got brand new E-cams in the closet..spoke to PMO on the Ride..anyway, as soon as I get my act together I gotta do the prep work..SSI/fume detector/Monty/Aircraft Spruce EGT system/MSD...the previous rebuild, 40k ago, saw 8.5 RS pistons/Raceware studs & rod bolts/Competition Engineering/etc..so I figure with 2 Big Rides and 10k of easy street driving/1 DE and it being tighter than a crabs a$$, and it being a carb eat carb world, I just gotta do it...I use 2 pocket warmers all winter...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2002, 03:54 PM
GIBSON's Avatar
It is tricky to measure, a true straight-edge is critical. I have a depth gauge that slips up against the straight edge and stays in place pretty well so I can get accurate readings.
I think it's important and worth taking some time to do it.
Here's my 73 set up to check the backspacing:
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 10-11-2002, 04:58 PM
Team California
speeder's Avatar
Bruce, What did you use to get your cases clean? I have my motor out now, got it pretty clean w/ a steam cleaner, but want it to look like yours. Very nice.
Denis
Old 10-11-2002, 07:59 PM
304065's Avatar
Porsche Crest Parallelism
A former colleauge of mine decided to tear apart his 68 911S motor to put on some solid tensioners, and lo and behold, he found that the PO had installed the port cam sprocket backwards, e.g. with the cup facing forward. The port chain was cutting into the aluminum case and there were chips in the sump. So I would definitely make sure that the chain alignment is straight as a string: the Stomski tool is worth it, even one time.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-11-2002, 10:41 PM
