s_wilwerding's Avatar
Heater questions
First, my heater does not seem to be working. I checked in the engine compartment and noticed that the plug for the heater blower was unplugged. I tried plugging the plug in with the engine running and the blower motor made this god-awful sound - it was running, but certainly did not sound right.
OK, I figure I have two options:
1. Pull out the blower and either fix it or replace it. One question - I already tried to pull it out and it doesn't seem to come out without removing the hard fuel lines. Does anyone have experience with this? It seems like it would be easy to damage the lines when removing the end fittings.
2. Backdate the heater. Since I don't really use heat that often, I wouldn't mind doing this. What's involved with doing this? What sort of parts do I need?
Thanks for your help.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 10-13-2002, 10:50 AM
PRO Motorsports
Tyson Schmidt's Avatar
The blower doesn't have to be running for the heat to work. It's just there to assist with the airflow at low engine speeds.
So, if you have no heat at all, you should check that the heater flaps are working, and that all the hoses are intact. You'll have to crawl under the car to check the flaps and the hoses from the heat exchanger to heater flaps.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-13-2002, 11:17 AM
schulr's Avatar
Send a message via Yahoo to schulr
it would be a good idea to go ahead and pull the blower and clean and lub the parts. They tend to get dirty back there. It should come out with out moving any lines, just remove the other colling and it should just come out. if it still has problems running after you finish cleaning, check the heater blower relay in the rear compartment on the left side of the engine. It is the smaller of the two relays.
Not sure on the 81, but with the 87's, this blower comes on when the engine is running for added cooling.
Bob
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 10-13-2002, 01:16 PM
