86FlatSix
JQ911's Avatar
help identify this part - linkage inside heater control
Replacing the carpets and noticed this linkage detached to that thingee. Its located inside the ebrake below the auto heater knob. It was already disconnected when we removed the housing. If we connect the rod to the linkage, we cannot mount the housing properly. Help.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 11-20-2014, 11:33 AM
That actuating rod ABSOLUTELY must be connected for your heat to work properly.
It may be that your housing is not mounted properly.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-20-2014, 11:39 AM
Oh Haha's Avatar
+1 to CCM911
It also looks like the red lever is missing. It should be attached to the other side of the linkage part. It comes out of the rubber boot, 1 slot for the ebrake handled and 1 for the heater lever.
You move(gently) the part with the ball end so it meets up with the rod. You may want to verify the workings of the heat flappers under the car. This unit is what controls them.
Pacific Blue
Wayne
Old 11-20-2014, 11:56 AM
Does this car have the Auto-Heat option?
Old 11-20-2014, 12:07 PM
86FlatSix
JQ911's Avatar
Yes it has auto heat. I asked this before coz my cousin's 87 had the 2 levers with red tip and mine had none.
Old 11-20-2014, 12:09 PM
turn the ignition on and the top knob to off and the servo, if it works, will move the rod forward. all the plugs need to be plugged in. some cars don't have a red knob because the servo controls everything.
206 637 4071
Old 11-20-2014, 12:38 PM
86FlatSix
JQ911's Avatar
Thanks guys! Will check JW approach tomorrow. The batt is disconnected while we are doing the carpets, wiring the rear fog lights and rear speakers.
Old 11-20-2014, 06:05 PM
There is a plastic snap cup with lock for each end of the rod. These break after years and need to be replaced.
It also doesn't hurt to clean out the guide tubes for the wires going to the flapper boxes so everything works smoothly when finished.
Bruce
Old 11-21-2014, 03:36 AM
86FlatSix
JQ911's Avatar
thanks JW
JW approach worked. You're the man! Wohooo! Thanks!
Old 11-21-2014, 11:14 AM
