Bear911's Avatar
69-73 turn signal box schematic
Dear Pelicans
I have started down the slippery slope of trying to "re-date" a long hood. I have managed to find most of the bits and pieces, but the one part that will make this project a go/ no-go is the turn signal boxes.
I live in the sticks and shipping fenders (even second hand ones) are proving prohibitively expensive. I know it is a long shot, but does anyone have schematic drawings of a 69-73 turn signal box (the actual metal brackets, not the housing..which I have.) I would like to fabricate new ones that can be welded back to the original fenders. The car will not be a concourse car, so it doesn't have to be authentic, just something that will work. In fact, it will stay a bastard, but just a bit closer to its roots.
I really want to put metal boxes back on the fenders and not go the fibre route. Also, I'm not too concerned about the dimensions etc of the lip at the wheel arch, just the actual mounting brackets for the turn signals and horn grills.
Any help/advice will be appreciated!
Björn
'76 911 Carrera 3.0 Targa
'69 911 Outlaw
'99 996 C2
Old 01-19-2010, 09:20 AM
Bear911's Avatar
I guess what I'm looking for is a diy way of getting this...
Pelican Parts - Product Information: OEM-90150304423
Björn
'69 911 Outlaw
'99 996 C2
Old 01-19-2010, 10:55 AM
Formerly reformed
My '65-'71 schematics don't appear to be broken down that far. I will look again this evening, though.
1968 911P (Paperweight)
Old 01-19-2010, 11:05 AM
I live in the same part of the world as you, and feel your pain!
Sounds like an interesting idea, so why don't you give me a shout - you can use mine for measurements if you want, and I can help you with the CAD work as well.
Cheers,
Willem
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 01-19-2010, 11:08 AM
Bear911's Avatar
Thanks Scott, any info is much appreciated.
Willem, thank you. Will take you up on your offer (will send pm.) Don't think it will hurt to at least try. I see the 65-68 box (part 901-503-038-22) is a rather complicated piece of sheet metal design, where as the 69-73 box (part 901-503-031-23) looks a lot less challenging to recreate.
Maybe I should find some second hand fenders on fleabay and get the seller to chop of the front end before shipping
Björn
'69 911 Outlaw
'99 996 C2
Old 01-19-2010, 12:12 PM
Formerly reformed
If we can't find an answer, just stalk someone with a concours-quality car and dismantle the front end while they're enjoying a meal out.
Old 01-19-2010, 03:36 PM
Bear911's Avatar
Hahahaha! Which one is faster...cutting torch or angle grinder? ( I need an evil smiley inserted here)
Björn
'69 911 Outlaw
'99 996 C2
Old 01-19-2010, 09:35 PM
Bear911's Avatar
Thought I'd better give this short thread I started in 2010 an ending, just in case someone else is thinking of doing something similar. Also,I hate threads with loose ends!
I started with a 69 that had been 'updated.' As mentioned above, I couldn't get second hand brackets so I decided to try fabricate my own. The before shot...
Stripping it down revealed that the original latch panel was still on the car, just repositioned. We were able to repair the hack job at the same time as the rusty suspension pan. Luckily for us, the 'offending customizer' had also left the inner edges of the turn signal box, which proved to be a great reference point with which to start fabricating.
First, I made up a cardboard mock-up to get the dimensions right.
I converted the cardboard to CAD with the help of my brother and had a local company cut the required shape out of steel with a CNC plasma cutter.
Then I hammered in the required edges.
Taping the turn signal assembly and horn grill into the correct position, I 'reverse engineered' the bracket. I used screws initially to keep it in position and then welded it later when everything was sorted.
So that it ended up like this (The rear lip was inserted later when we re-did the wheel arches)
The end result...
Björn
'69 911 Outlaw
'99 996 C2
Old 04-01-2012, 02:22 PM
Grady Clay's Avatar
Björn,
Great recovery from a ‘bumper change’, particularly you being in SA, not LA.
Congratulations.
More pictures please.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-01-2012, 02:39 PM
Bear911's Avatar
Thanks Grady! Help is fortunately never further than a PC away :-)
There are a few more pics of the car on the RSR replica and white p-car threads, but will try to add a few more later.
Cheers
Björn
'69 911 Outlaw
'99 996 C2
Old 04-02-2012, 05:39 AM
Hi, guess its an old thread, but worth a shot.
You wouldnt happen a cad drawing of those parts that you would like to share
Im located in Bahrain and backdating an SC. No parts available here and old bits cost a fortune.
Hows SA these days.. My wife is from CapeTown!
Cheers
Tareq
1997 993 Carrera S
1983 911 SC - Project Car - Sold
1988 Rover Mini - "Miglia Project"
2001 Ducati 748 - Track Bike - Sold
Dallara F302 F3 single seater
Old 11-24-2012, 10:12 AM
jakz's Avatar
another try at reviving the old thread, anyone has drawings for this?
"It's only temporary unless it works"
1974 911s turbo-look stock 2.7 engine "Dirty Martini"
1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU
Old 12-01-2014, 03:36 PM
Elombard's Avatar
can you actually buy those repair pieces he shows in the first slide? I have to look into that
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-01-2014, 06:05 PM
You can purchase the parts from the Porsche dealer
Left side 901.503.043.23
Right side 901.503.044.23
Bear911 was kind enough to send me the cad drawings of the parts he fabricated but in the end we used the porsche parts and fabricated the sheet metal extension for the fenders behind the turnsignal lights.
1997 993 Carrera S
Old 12-01-2014, 09:19 PM
