Quick fuel pump question
I have searched this before and thought I knew the answer, and saved the
thread but cant seem to find it. I have an 87 Carrera Targa that is in need of a fuel pump. I thought I read here on the board where a crossover BOSCH pump. I seem to recall a BMW part number? I just called to order the pump and couldn't recall the part number. That 190 buck sticker shock. I thought the thread I found said it was 135-140 or so. Also, a part number for the in tank filter if you may know. It is 50 from our host. Thanks much, Scott |
After a quick look-up for Bosch fuel pumps for an '87Sc I came up with the Bosch part number:
0 580 464 069 Bosch Vehicle Component Applications Parts Catalogue https://www.google.com/search?q=0+580+464+069&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US fficial&client=firefox-a&channel=np&source=hpGood luck!
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
I kept this record of the fuel tank screen, but it looks like I bought a sealing ring to go with it for $5 more. don't recall if it came with because I wrote the number down for it as if it was separate.
911-201-143-00-OEM 911-201-141-00-OEM
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
At $50, the screen and seal are a little over dealer list. While replacing the seal is a must, the screen can, if it's undamaged, be cleaned and reused. $190 for the pump is less than half of list. Pardon me for saying this, but if $190 for a fuel pump is too steep for you, maybe you're driving the wrong car. BTW, the stock pump for a 356 is about $432, making yours look pretty inexpensive.
The Cap'n |
filters and I'm sure mine will look very much like yours. It along with some hose are already on my parts list that is being held. Question: By chance when you removed yours did you happen to run your finger around inside the tank to see how much funk was in inside? I wouldn't be at all surprised if I need to remove to be cleaned. Quote:
help me get off the couch and keep moving. When I figured out being beat up by a nice inshore chop did me no good, I went for my childhood dream car Being a disabled Vet. I try to save where I can. If I am able to save 20-30 dollars on a part I'll do my best. I fully expected someone would have a reply about me wanting to save money on a 200 dollar part. Several of our parts crossover to lesser expensive, just because they do not have a crest. Funny how some posts draw a certain reply while others seeking a relay and finding it less expensive from BMW, do not. Thanks for your help guys, Scott Last edited by FLYONWALL9; 12-04-2014 at 10:28 PM.. |
Sorry the pics posted sideways. There was a little bit of rust, but no gunk on the screen on in the middle of the bottom piece, but I am sure it wasn't pretty in there. I'd considered it for cleaning, but I wasn't sure if the thin screen would last longer, and the frame itself is plastic. I had the means at the time and was also doing the FP and the fuel lines, so this was a while-yer-in-there job. slightly off-topic, I replaced my speed and ref sensors with BMW parts - still Bosch products at half the price - one inch longer for convenience too if I recall correctly - should you ever need'em. peace, Dan
INDEED!! I have read this also and haven't forgotten. I may still have to replace those. It will be my last result to fix the issue I currently have. I have either tested or replaced everything else. ![]() Cheers Scott |
I'm sure I read on the forum someplace that the pump is also used on another
car. I just cannot for the life of me find that post again. |
OKAY, I found some information. our pump is used on a host of vehicles.
The BOSCH part number is 69458 I also found this thread to be quite interesting. Which BOSCH fuel pump is correct? |
just read the thread - wow - I could've $aved.
