I've learned over the years never to pull the plug wires on a warm engine if you can help it. I've pulled wires out of the heads that way or have disturbed otherwise good wires. Too much fiddling with the wires while they're hot never did me any good.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
I made my own set of shorter cables and routed them like this:
![]() I used a set of pre-built magnacore 8mm cables and then shortened them at the distributor side connectors. I also added a dab of silicone between the connector and the wire when I reassembled them. Most likely your cables where arcing to ground inside the valve cover area. Bad cables tend to do this at peak power and hi-cyl pressures. Quote:
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 01-08-2015 at 06:20 AM.. |
Yes,Lesson learned. Never happened to me before. Thanks for feedback
Ps Your engine looks cool. I like your intake set up as well. |
And this seemed to fix it?
1986 Bosch Icon Wipers coupe. |
Looking in the engine compartment at night while the engine's running can be helpful. You can actually see arcing in some instances if you have a grounding problem. In the late '70's I had a 914 that tried to strand me out in the country on a snowy night. If I hadn't spotted the sparking, I would have been up the creek for sure.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Update.
Still issues. The leads did not fix the problem. It is better but not the fault. Ecu Check in another car and is fine. Variostat tested the CHT sensor and is fine. So injectors away to be serviced and checked. Will keep you posted.
What about spark plugs? What are you using and what's the gap?
I am using NGK B8EGV . GAP .8mm have also tested bosch platinum 4's and NGK BPR6EY also .8mm Found the NGK B8EGV the best here .
NGK B8EGV at 0.8mm is fine. But never use multi electrode plugs like the platinum 4's the old school coil in our 3.2L motronic cars may not have enough output to jump multiple gaps that wide. Stick to simply single electrode plugs.
Is there a trick to remove the WOT switch cable? Doesn't seem to just pull off and I don't want to damage the cable. My switch doesn't seem to be working and I wanted to test it. Thanks.
Quickest is to have a helper. Engine and ignition off. Remove throttle switch plug put your multi meter leads on the top two pins of the sensor. Set to ohms and you will have a No Continuity reading. Get your helper to floor the throttle At this position you should have continuity. If not further testing is required. Check the power to the plug, Ignition switch on ( not running) should be 5 VDC bettween plug terminals. If fine there is a chance it is out of adjustment. Get yourself a Bentley Manual. All test info is in there and is essential for the 3.2 owner. 2nd if you are on your own. Remove your ECM plug Its the big one under the seat. ( as I am sure you know) Then using your multi meter on Ohms put one lead on pin 3 of the plug and one to ground, No Continuity at this point. then put your foot on the gas pedal.... to the floor if you have Continuity then the switch is working. no Continuity and further investigation is required. tests all wiring from throttle switch to ECM plug and because it is in the car you can read the meter easy. I am no expert but i hope this helps. |
Thank You Pelicans. And Pelican Parts for all the help and Service.
With time running out I had to do a few things to the car before testing so no isolation pin point sorry but it is running very well so I am Stoked. Yes it is finally FIXED. So in my last attempt at solving the issue. I had the injectors ultrasonic cleaned serviced and flow checked. ( they didn't test them first so have no data on operation before and after). They are even at 240cc. I also removed the intake manifolds and replaced gaskets. I recommend buying the thermal spacers as well as the gaskets as they were all breaking down on my car and were hard to clean. took ages. And I pulled the AFM apart and very carefully moved the manipulator arm to run a new track. ![]() Bolted it all back together and BOOM all sorted. Running meaner and louder than ever. So happy. Thanks to all. Thanks to Pelican for supplying the parts I needed in a timely manner. Regards Alex |
Somewhere in the South Island of New Zealand.
https://www.youtube.com/watch?v=wEbAJFL6Q5w&feature=gp-n-y&google_comment_id=z13siz3znrvfyxfga04civbhoynov134 55o |
