Slippery Slope Victim
Dash - What goes here?
I removed the old alarm from my car and the red indicator light was drilled and placed into this recess. My question is, what possibly goes in this space, I presume something optional.
TIA
MikeČ 1985 M491 |
Probably the optional rear window wiper switch.
My 82 has no hole and nothing else there...and no rear wiper either...so db_cooper's answer is probably correct.
It's a holdover from the front wiper speed control knob (potentiometer) found on 74 and 75 cars. Porsche created a new dash facia for 86 that didn't have this.
Tru6 Restoration & Design Last edited by Shaun 84 Targa; 12-07-2014 at 03:26 PM.. |
Thanks all. I am trying to clean it up, the hole won't do, I'm too anal.
MikeČ 1985 M491 |
Maybe I can find someone who has a donor car and cut a piece of material to make a patch/plug.
MikeČ 1985 M491 |
I would consider some kind of cool aesthetic patch Mike. You've got to take everything in the area off to replace that piece. The worst being the HVAC control panel with cables going into the trunk to operate the various vents.
Tru6 Restoration & Design |
For right now go to a decent hardware store and get a plastic plug that fits the hole.
My PO drilled a hole for a Clifford alarm keypad just to the right of the ignition switch, and when I took it out the hole looked terrible. So I cut a piece of this tape to size, and stuck it on. Looks really surprisingly good:
universeman, sounds like a good idea. is the tape textured?
MikeČ 1985 M491 |
Banned
On 1986 + models, the small, round grill for the auto-heat temperature sensor goes there (not sure on 1985). I guess your car has the older style sensor between the sun visors . . .
Mike, it's not textured, but it hides itself really well on the dash. It has a matte finish, but is smooth (thought not slick).
I used it also to black out my anodized trim which was fading from black to bronze with age (temporary fix). That repair is perfect - I can't even tell it's still there. It is amazing stuff. Picture electrical tape but better, no gummy adhesive, and 2" wide. Very useful stuff. |
muck-raker
auto vinyl repair kits from your FLAPS will cover that nicely. Or, you can purchase one of those miniature Porsche crests, might look fine.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Vintage Owner
Why nor simply put another switch in that spot? It could be used as a stealth fuel pump shutoff or any other function, or do nothing at all other than fill the hole in the dash. At least it would look factory original.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
The upper of the three air control levers, to the right of the offending hole, also acts as a switch for the fresh air blower motor. As a switch, it is a poor design - open contacts sliding over copper fingers. When I got my '77 in 1984 several of these contacts had burned out. No way to fix or replace that, really, short of a complete replacement assembly, which might just fail eventually anyway.
So I put a rotary contact switch in the spot where your hole is. It was from a later 911, and was used to control a fan, had the right number of contacts as well as an off position, and looked like it belonged there. Wired the blower to it. Works just great (as long as the blower works, which is not as long as it should be, but that's a different matter). You could do the same. Wire it up now, or wait until the slide switch stuff starts failing. |
OK brain trust,
If I were to find a replacement dash trim panel, how would I go about doing the R&R without screwing it up?
MikeČ 1985 M491 |
The Bavarian
![]() Christophorus = patron saint of car drivers - Manfred
'80 911 SC Targa black/black |
Sorry, but I am extremely anal, maybe OCD....
I need it to go back 100% or I won't sleep.
MikeČ 1985 M491 |
Remove clamshell Remove knee pad and ash tray Remove fiberboard cover over fan in trunk Loosen 7mm nuts locking the cables to the HVAC directional vents, pull cables out Remove passenger side vent and associated tubing Remove 10mm nut holding the HVAC control levers to the body Remove HVAC wiring to body and lights to it Pull/push control levers through multi-hole grommet, can just remove entire grommet from body Pull control lever unit out Take pictures of the area for reference Using a putty knife, carefully wedge it under the facia and cut up to remove. If in excellent shape, it's worth $100 to anyone with a 74-75 Clean the dash face. Practice putting the new piece on the dash Use contact cement on both surfaces to mount again, you only get one shot
Tru6 Restoration & Design Last edited by Shaun 84 Targa; 12-08-2014 at 05:01 AM.. |
Thanks Shaun.
I have 2 choices here. 1 - Make a presentable patch from stock material, a round patch w/ spray adhesive 2 - You come to Brooklyn and do this. Beer will be served after successful completion. I guess it's choice 1....
MikeČ 1985 M491 |
