Roping in a windshield ?
I'm going to attempt roping in by windshield on my 75 Targa. Safelite refused the job.
I've got everything prepared other that installing the rope in the seal. My question is what size and type rope do I use. A picture would help showing the install. Thanks in advance.
Dave K |
I would rather be driving
I use layout string. This is a multi-stranded string found at HD or other home improvement store. Available in a spool or roll and in many colors. It is strong, waxed and highly flexible.
Go around the window channel inside the seal 2X. This way if/when you miss a section you have a second shot without resetting the string. Installing the glass is the easiest part of the whole endeavor. Putting in the window trim into the seal is the absolute worst part.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I use soapie water in a spray bottle also. Just don't push on the lower corners too hard. (crack!!!)
74' 911 w/3.2L (sold) 95' 993 C2 Triple Blk Cab. 02 Honda Superhawk (sold) 2018 Toyota Tundra Limited 2004 CRF250X |
Slippery Slope Victim
I use nylon mason line, about 1/8" thick. Use PLENTY of liquid soap, a nylon "bone" tool is also a huge help when having to work the gasket.
If possible, get an extra set of hands!! Never had a problem.
Mike² 1985 M491 |
I wrapped the string 3 times to make sure I wouldn't need to restring it. With a thin enough string, you can just pull it out if you get it full seated and you still have a few more passes.
I used Windex to lube it to install. Easy to spray, just the right amount of slickness, and dries. |
PCA & MCSCC Instructor
Slather everything with "Goop" hand cleaner.
This will really help the roping in process, and then it just goes away. Make sure to have a helper. The windshield is the easiest of all the windows. |
Almost Banned Once
All good info but were do you "start" the string? Top or bottom?
Bottom I'm guessing...
- Peter |
I have always started bottom center.
Mike² 1985 M491 |
Bottom center
Registered speed offender
I started mine from the top after reading quite a few threads here. It took me three tries to get it right... that damn trim kept coming out somewhere. If that happens, save yourself the trouble and start over by pulling the trim back out and starting from scratch.
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html |
Wander down to your local Walgreens and get some KY Jelly/astroglide/favorite brand.
Slick as...ehem...snot...ehem...and water based, so it'll dry and disappear.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Dave... this line is just over 1/8". Some put talcum on line---that gets messy. Others use soapy water... not so messy. Suggest wrapping line around seal twice. If seal does not pull out first time... you have second shot at it without starting over.
![]() Can see line plowing seal up here as it should...
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
WHen you place the windshield w/trim and seal into place, what is the best way to tell if you have it centered before pulling the rope? What the seal looks like on the pinch weld from the inside or where the seal sits on the car from the outside?
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
Thanks for all the responses and tips!
I plan to do the job tomorrow.
Dave K |
The correct way to re-position is to use the suction cup handles stuck to the windshield. I just put my hands on the outside surface of the windshield and pushed the windshield in the direction it needed to go. My buddy that helped me install the windshield said that mine was the first he helped install that didn't need a strip of rubber positioned across the bottom of the windshield opening enable the seal to cover the entire opening across the top. When mine was installed, I didn't have to play around with a rubber hammer and shims to shape the outer edges to cover the corner opening. So I got lucky in that respect. When the seal is fully seated on the pinch weld, on the inside, all you will see is a uniform rubber lip completely covering the pinch weld. If I were home, I'd take a pic to show you. If I remember tonight, I'll try. |
Interesting point WH. Put in dry and once seal has got a few inches of lip... there's no moving windshield.
I have used clothesline, a popsicle stick along with lube, patience & light touch. Good luck.
Well everything went good until I started moving the corners in place. Lost my patience and buggered up the trim pieces. Yes I made the wood stick.
Is was easier that expected- the lip went in fairly easily. I think main issue was I didn't form the trim pieces to the exact contour of the widow glass before installing the trim in the rubber windshield seal. Also, maybe the window wasn't not properly centered in the frame before pulling the rope. Finally, I would lather up the windshield body frame with soap, so the windshield assembly can be moved easier to its final resting place. It will do for now- had to get it out of the living room before the holidays. Thanks all! Best regards,
Dave K |
Good job Dave!
Dave, was your trim new or did you use the old trim?
