recommendations - engine mount crossmember
I tried to do what I thought was a simple job today...replace motor mounts. They are original (1985) and the bolts wouldn't budge. I was surprised how the cross member flexed. I tried to several ways to counter the torque, but couldn't. Found tears in the cross member near the bolt receptacles. Now I need a new cross member...hopefully something stronger with unthreaded receptacles so I can go with bolt and nut. Any recommendations?
Thanks, Mike |
That does happen. Replace it. Or have it welded.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Northern Motorhead
Rennline is having their 15% off X-Mas sale,they have a nice reinforced stainless engine crossmember,i installed one in my car after welding the OEM one for the second time ...
Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Mike,
I had similar issues on my '84 Carrera's engine mount crossbar. Bolts would not turn and the crossbar was developing "flex" cracks at the ends. I ended up replacing the crossbar with the Rennline RSR style crossbar. The crossbar ends where the bolts go are heavily reinforced so there should be no flexing in the future. I am very pleased with the Rennline crossbar. Bruce |
Almost Banned Once
This one
(Original from an SC RS)
- Peter |
Has anyone modified the stock crossmember by welding in some gussets to strengthen it?
Almost Banned Once
- Peter |
The SCRS Crossbar is just a little extreme as it did come from a car that was used aggressively on the European Rally Championship.
The more common RSR Crossbar just uses a second flange to increase the stiffness and these work quite well but can still yield. Adding a couple of gussets on the corners works quite well. ![]() If you also make the Crossbar from a stronger material it will improve its reliability. We made a small batch of RSR Style Crossbars using a material with the trade name of DOMEX 700MC. (They sold out quite quickly) This material has been developed by SSAB for military vehicle applications. It has a yield strength that is around 4 Times greater than a typical CR4 Deep Drawing Quality steel. The yield strength is about 120000 psi but it retains the same level of ductility and weldability as more conventional mild steels. It also retains its impact properties to very low temperatures. For the relatively small quantities used in the engine crossbar the price premium is insignificant but the performance enhancement should be very good and prevent both deformation and subsequent failure. Last edited by chris_seven; 12-11-2014 at 12:35 AM.. |
Our host sells the Rennline RSR Style Engine Crossmember Bar. It is reinforced stainless steel and is offered in painted black or brushed stainless.
I opted for the black bar since since that was a closer match to my OEM crossmember bar that I removed. I also used anti-seize on the new mounting bolts, so they should come out a bit easier next time. Bruce |
Gussets is what they are called. I made mine. But a good shop that welds, and fabricates can do it.
abides.
Does anyone sell a gusset kit for these? I can weld them on, but I don't have the tools to cut or form them.
Graham 1984 Carrera Targa |
Wer bremst verliert
If you have a handheld jigsaw with a metal blade you can cut them out. Use cardboard to make a template then trace it out on some scrap metal.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
heat the ends.
Ordered the black Rennline unit on sale...Thank you very much!
Here is a view of the tears in the original one: ![]()
Boy, those cracks looks familiar.
![]() With the Rennline Crossbar you should not have that issue any more. Enjoy, Bruce |
Anti seize when you put the next one in as well.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Before attempting to loosen, be sure you raise the engine from beneath until you see all the weight come off the mounts. The rubber will expand out between the big metal washers.
Mine were stiff, but removed without any cracks once the weight was off. I used a long breaker bar, and I applied the pressure in such an angle that I wouldn't bend the crossmember.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Restoration Design sells a RSR replica mount that looks interesting
gone 82 928 Comp pkg 83 911 SC RS 69 911 T lightweight canyon carver outlaw soon Lotsa Ducati's 99 Triumph 995i track bike www.porscheresto.com |
