sugarwood's Avatar
Can I sharpen instantaneous RPM throttle response for rev match pedal blip ?
When I downshift, I do the rev match. I also sometimes try to double clutch. Both require a quick blip of the throttle.
You want that blip to be as fast as possible since you're off the gas and coasting during that time.
For rev match, I usually have to blip the throttle twice.
When I depress the clutch, RPMs instantly fall to the idle range.
A downshift usually means you'll be finding the lower gear at 3000RPM. But, a quick blip does not get me near 3000.
Bottom line is that I blip it twice to get me near 3000.
I would not even notice this in a commuter car, but because of this throttle blip, I would like my throttle to be more responsive.
If I blip too quickly, the RPM's don't instantly respond.... like when flood a car or motorcycle when giving gas, and the engine responds by bogging down (but no where as bad as that)
My idle is smooth and consistent. Car finds idle almost instantly when started. Fires right up and never stalls.
So, my 911 might be working as it was designed, but I would prefer a more crisp instantaneous RPM response from the throttle, if possible.
Other threads have suggested adjusting the mixture. Is that hard on a 3.2 ?
Here are some old threads I found.
Throttle response not what it was
Odd Throttle Response
throttle response?
1986 Bosch Icon Wipers coupe.
Old 12-13-2014, 09:19 PM
Driver
Noah930's Avatar
Is this a problem you have only in your 911? Or in manual-transmissioned cars in general?
1990 Black 964 C2 Targa
Old 12-13-2014, 10:27 PM
Depress gas pedal further so engine revs higher. If either double-clutching and/or just rev-matching, the engine revs should end up to be the same revs as if already in the lower gear.
Old 12-13-2014, 11:58 PM
Bill Douglas's Avatar
When you downshift/double the clutch, don't lift off the gas. Have enough foot on the gas pedal that the revs increase by 1,000rpm or whatever while you depress the clutch, but don't do that blippy thing.
Old 12-14-2014, 12:04 AM
Moronic throttle response is kinda slow. Has it always been this way on your car or a recent change? I found that a Steve Wong chip sharpened up my throttle response and is useful while double clutching.
Old 12-14-2014, 12:16 AM
DanielDudley's Avatar
Lighten your flywheel. Lube your pedal and linkages.
Old 12-14-2014, 03:34 AM
gliding_serpent's Avatar
chip helps response, and check that there is no play in your throttle linkages. they might need adjusting. My throttle is very responsive. Most important, practice. Every car I own is a bit different. Of my cars below in my sig, the 911 is the most responsive.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 12-14-2014, 04:43 AM
cycling has-been
bkreigsr's Avatar
Lighten the power train's rotating mass.
As suggested, cheapest/easiest, is to start with the flywheel.
Bill K
Old 12-14-2014, 05:39 AM
Slippery Slope Victim
NY65912's Avatar
Bill K
True, but you might not like it for daily driving.
Mike²
1985 M491
Old 12-14-2014, 06:06 AM
sugarwood's Avatar
No comments on old threads advising to adjust the mixture?
Bill K
A $500 part and 8 billable labor hours for the engine drop is not in the cards for such a minor thing, which might not even be a thing.
Ok, I will try lubing the linkages. I'll trace all the linkage back from the pedal as best I can.
Interesting. I have never heard of this. Is this a common technique?
Old 12-14-2014, 06:42 AM
I don't know if it's common or not. It works well.
Old 12-14-2014, 10:05 AM
Platinum Member
dad911's Avatar
Heel-toe. Which in my case is left side of foot on brake, right on gas, rolling the foot to work the gas.
Old 12-14-2014, 10:24 AM
Buy a new car. If that does not work get a new foot. ;-)
1973 BMW 2002Tii
2016 Ford Focus RS
Old 12-14-2014, 10:38 AM
porsher
aston@ultrasw.c's Avatar
Adjust the brake linkage to lower the brake pedal a little.
Now when your "heel" hits the throttle it really opens it up!
No charge.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 12-14-2014, 10:46 AM
Elombard's Avatar
I dont know that there is a light flywheel for a 3.2 car since it has the trigger for the sensors built in?? Definitely go with the aluminum Pressure plate next time you do the clutch. Made a nice difference on my last 3.0 SC motor and its the same PP on a 3.2 with 915.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-14-2014, 10:56 AM
sugarwood's Avatar
Originally Posted by pmax View Post
These engines run to redline in an instant without load.
An instant? You must have a very heavy lead foot?
Maybe I need to start stomping the pedal instead of blipping it gingerly.
Old 12-14-2014, 12:10 PM
All you have to do is press a little further and perhaps longer to get to the correct RPM in synch with the clutch and gear change.
Without load = in neutral. Try it. However, at WOT (wide open throttle), the engine might self-destruct in a few seconds.
Sherwood
Old 12-14-2014, 12:21 PM
Still here
pmax's Avatar
There's no hesitation or bogging down like you mentioned in your OP. The engine responds instantly in my Carrera and reaches redline faster than you can say 'one th ...'
My suggestion... give it an Italian tuneup. It's free
Old 12-14-2014, 01:30 PM
The 3.2L cars rev very quickly. If your car isn't getting to the right revs, then something is wrong with your car or your technique. My guess is that it's your technique or a combination of the 2.
Old 12-14-2014, 04:29 PM
No charge.
You just solved my dilemma of my rennline gas pedal being too high for proper heel toe under heavy braking (i.e I want gas to be level with brake when brake is fully depressed). Answer: Adjust the brake pedal linkage. I will read up in my Bentley tonight!
1973 BMW 2002Tii
2016 Ford Focus RS
Old 12-14-2014, 04:57 PM
