Throttle response not what it was
When I first got my 1980 SC a few months ago, the throttle response was absolutely electric. I would blip the throttle and the revs would just SCream to-wards red-line.
Recently the throttle response has slowed down quite noticeably. I cannot correlate this decrease in responsiveness to any particular thing. No recent maintenance events or improvements correlate to the decreased responsiveness.
I observe two new behaviors:
1. Blipping the throttle in neutral the revs climbs more slowly with a slight roughness.
2. When the car is just beginning to warm up, the revs have a hard time stabilizing when the throttle is suddenly closed.
Thanks,
Matt
Matt West
1980 911 SC
Old 05-21-2005, 05:51 PM
Might do a search on the frequency valve.
Joe
Old 05-21-2005, 05:57 PM
Virginia Rocks!
VaSteve's Avatar
When you got it a few months ago, it may have been cooler. You may need to lean it out a bit. Souk posted a thread on this last fall...search on that. I need to adjust my mix as well...lazy me..
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-21-2005, 06:01 PM
You are getting use to the car. When I first got my 911, it was Faaast. Now I am ready to make it faster, but $$$$$$$$.
Jeff
Old 05-21-2005, 06:15 PM
help 911sc starts but backfires when given any gas
Old 05-22-2005, 02:21 AM
Designer King
Paulporsche's Avatar
Second VaSteve. See if leaning i/16 turn helps. If still not ,try another 1/16 turn. If that doesn't work, let us know.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-22-2005, 07:51 AM
PorscheGuy79's Avatar
What about the vacuum advance? I found a similar problem with my car and removed the hose from the vacuum advance, plugged the holes, BAM whole new car.
I might not know if this is right, but if all else fails I just wanna throw this out.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 05-22-2005, 08:53 AM
Just wanted to update this post with the answer...
The fuel air mixture was off. CO was at a 6 and adjusted down to 2.5.
Probable cause was cleaning the gunk from around the air sensor plate.
Throttle respone is electric again
Matt West
1980 911 SC
Old 06-01-2005, 06:50 PM
