Sealing up CIS air box - while still on the car?
My CIS air box seems to be leaking quite a bit along the seams that join the upper and lower sections. I confirmed this using the vacuum-cleaner-in-reverse-with-some-soapy-water trick (which worked great!). I have investigated the rest of the connections and they all appear to be tight.
This is a weird situation: This is a newly rebuilt motor with all new injector sleeves, seals, runner-to-airbox tubes, etc. Looks like the air box seams opened up shortly after first start-up. (I had bubble-checked the air box after cleaning it up prior to rebuild. Obviously, I did a poor job.)
To me, it looks like it's possible to remove all the screws joining the two halves together and disassemble the thing while it is in the car (without pulling the entire CIS system). Has anybody successfully done this?
Thanks for the help.
Old 11-01-2013, 08:20 PM
Senior Advisor
James Brown's Avatar
no but you can remove the whole plenum after removing the runners and most of the upper components in he car. After that you can get some epoxy on it in those hard to get places and verify that it is air tight, and put a pop off valve in it if it doesn't have one.
08 Cayenne Turbo
Old 11-01-2013, 08:26 PM
ROW '78 911 Targa
timmy2's Avatar
Definitely need to remove it from the car.
Even though the seam is leaking it is still glued together in a lot of places internally.
The 2 halves are joined with a square shaped tongue and groove all around the perimeter.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-01-2013, 08:38 PM
OK - Thanks for the info. I guess I'll order up intake gaskets before popping that apart.
I do have a pop-off valve, but no longer sure that installing it was a good idea after reading Pete Z's explanation of some common air box misconceptions.
Old 11-02-2013, 06:38 PM
Daviboy's Avatar
Dont even bother trying to repair it I had the axcat same problem and tried numerous ways of 'glueing' the airbox back together all of them failed. Do yourself a favour and buy a new one or you will contiually be chasing vacuum leaks. Try and find an aluminium one they are rare but the best and you will never need to worry about cracking.
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 11-03-2013, 01:08 AM
Does anybody know what plastic/resin the air box is made from? ABS? Other?
Old 11-03-2013, 07:09 AM
Sorry - Should have searched before asking the question. Another thread indicates that it is polypropylene or polyethylene (in which case I might be able to get this thing welded to seal). I'll update whatever it is I eventually do.
Old 11-03-2013, 07:17 AM
JT JT is offline
New User
Did you ever get it sealed properly? If so, what did you use? I heard Sashco Lexel will work.
Old 08-08-2014, 02:38 PM
I haven't sealed this up yet; it's been running pretty well in the good weather lately and so I've been enjoying it. I'll probably tackle this fall.
Old 08-08-2014, 08:07 PM
if it split cleanly along the tongue and groove seam, you can use glues rated PP. they bond/melt the type of plastic used for the airbox. HPPE glue, it think that's correct, works too. (maybe it's HTTP). if it's busted beyond the seam, forget it, new box.
206 637 4071
Old 08-08-2014, 08:28 PM
JT JT is offline
New User
Using the vacuum up the tailpipe vac leak test, i was getting bubbles around the seam. The box is out, there are no cracks, the screws are out, but the box won't separate. That tells me it was resealed once before as there is some gummy stuff (sorry I'm not too good sealing compounds) at the bottom of the screw threads. Some of the weren't completely tight. Can I just put them back - tight, and put some glue/sealer along the edges?
Old 08-09-2014, 06:21 AM
try some slightly larger sheet metal screws for a good bite.
206 637 4071
Old 08-09-2014, 06:31 AM
JT JT is offline
New User
Will do. Any sealer/glue on the edges?
Thanks,
Old 08-09-2014, 06:33 AM
Designer King
Paulporsche's Avatar
I think what John means is HDPE (high density polyethlene) adhesive.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-20-2014, 08:26 AM
Updating with some recent testing. I eventually pulled the CIS off the car to fix the airbox. Let's just say that gravity always wins and the original airbox shattered into a few pieces. I picked up a used airbox with similar sealing issues along the seam.
I have determined that the airbox is not polypro or polyethylene (is most likely PPS or polyphenylene sulfide). Most of the adhesives for PP/HDPE also work for PPS (but there should be more adhesive options for PPS).
Old 12-20-2014, 03:14 PM
Stranger on the Internet
patkeefe's Avatar
I have blown up some airboxes with my turbo, and a few backfires, which resulted in my doing some substantial airbox testing. I have found that plastic airboxes leak. Maybe not when they were new, but they do now. I will go so far as to say if you have an airbox, it leaks. Further, if it leaks, it is virtually not seal-able.
Patrick E. Keefe
78 SC
Old 12-20-2014, 03:29 PM
