Va914's Avatar
Front strut and hub help
I bought a '74 911 front end without hubs. I found a set of 914/6 hubs with all associated hardware. It turns out the hubs fit great but the keyed washer and retaining nut (allen) are too small of a dia.
Can anyone confirm this or add some ideas?
Does anyone have a set of front wheel bearing hardware that will fit a '74 911 front end?
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 10-19-2002, 10:11 AM
Senior Member
Hello
The 911 has different axle pins and bearing sizes.
However the hub is the same unit.
Grüsse
Old 10-19-2002, 05:08 PM
Navin Johnson
TimT's Avatar
At some point Porsche increased the diameter of the end of the spindle and changed thread pitch as well. You will have to get a later style washer and clamping nut.
With early hubs on later spindles you also may have to provide clearance for the larger clamping nut required for the later spindles(in the area where the clamping nut resides)
I have access to a lathe so it was a pretty harmless modification.
'69 911 GT-5
'75 914 GT-3
and others
Old 10-19-2002, 05:35 PM
Senior Member
Hello
The Bilsteins have the larger spindles later on the 3,2 Porsche used the large spindeles with the sportstruts and finally with all.
very easy to detect on the additional braket for the brake wearcontact wireloom.
Grüsse
Old 10-19-2002, 05:53 PM
Va914's Avatar
Do you guys think the nuts and washers are something I can find used? They are not too cheap new.
Thanks for the help.
Kerry
914-6 in the Werks
Old 10-19-2002, 06:04 PM
