Start Problem
My '86 911 has just started a new problem. Some history: The engine has always started on the first 1-2 revs and settled into a smooth idle almost immediately. I had a 60K full service done in Sept.and the car ran flawlessly on a 2400 mi. high speed dash up to Yellowstone and back in early Oct. Two days ago, I noticed the start drill had changed. After the car has sit for 24-36 hrs, it still starts very quickly but seems to be rough and rocking for 5-6 seconds before settling into a smooth idle. The rest of the day all starts seem normal. I suspect pressure to the injectors is bleeding off over time. I've also noticed an increased gas smell around the car in the morning. Is this a known problem? Does anyone on the BB recognize the symptoms? Would appreciate your ideas and/or fixes! Thanks in advance.
george 86Targa "Jessie" Eternity is long, especially near the end! |
Have you replaced the O2 sensor or the idle control valve yet?
1984 Targa |
my '86 starts straight up but "hunts" for a few seconds and then settles to smooth idle. sounds similar.
nothing to worry about.
Rich ![]() '86 coupe "there you are" |
ever it is causes the smell of gas to be fairly strong when I get in the car in the AM.
I have a 86 911 also, during the spring and summer months, the engine starts and idles smoothly after a couple of seconds. As the weather gets cooler, I notice that the engine will idle a little rough for about 5 seconds and then settle into a smooth idle.
The behavior your describing sounds perfectly normal. Hope this helps. Lee
Lee's Toys, 1986 911 Coupe (139k miles) - Running strong, daily driver. Stock A/C, blows 35 F air when outside temp is about 90 F, in Seattle!!!!! 1987 911 Coupe with LSD (64k miles) - G50 a little more forgiving, garage queen. 1998 4Runner SR5 V6 4WD with TRD Supercharger - Supercharger gives the 4Runner a dual personality. With this great summer weather, 4Runner has become an garage queen too. |
what about if you turn the ignition on for a fe seconds before starting - let the pump build up pressure??
the fuel smell is not normal and a bit worrying. i had a smell that turned out to be the line out of or by the pump leaking, you might want to check that and other lines. easy to do 'cause they'll look "wet". good luck
The O2 sensor should be replaced every 60,000 miles. I'm not an expert by any stretch of the imagination, but my understanding is that it plays a part in fuel mixture. What you're describing sounds like a fuel problem, and if the sensor is going bad it's possible once it heats up it "rights" itself a bit and the car begins to perform normally. Since the manual calls for replacement at 60k, if you have that kind of mileage and haven't replaced it yet, it's worth doing.
On my 84, I had a problem where intermittently the car would fluctuate at idle between 800 and 1100, up and down, up and down. I replaced the idle control valve, and the problem went away. Both of these are relatively easy and inexpensive "fixes," and present a good place to look before you begin looking at more expensive and complicated problems.
1984 Targa |
02 sensor only works when engine is warmed up, but the idle control i dont know...........
If you 84 is wired right, the fuel pump only turns when the key is in the start position or the car is running.
If you can smell gas there must be a leak or fumes are escaping from the return circuit. Points to check are the the rubber line from tank to pump, pump banjo fitting, fuel lines that run from front to back through tunnel, the connections to the charcol box, and many fittings in the engine bay. Let us know what you find.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
