-   -   Backdate SC (http://forums.pelicanparts.com/porsche-911-technical-forum/846744-backdate-sc.html)
flyn-hawn 01-14-2015 10:34 AM
Backdate SC
Just got the motor back after putting webcam 20/21 got most of the stuff on except oil lines, alternator, becase I still have to do the fan. I could not wait so see what it would look like with all the shiny stuff on.
From this
http://forums.pelicanparts.com/uploa...1421260116.jpg
http://forums.pelicanparts.com/uploa...1421260418.jpg
to this
http://forums.pelicanparts.com/uploa...1421259788.jpg
http://forums.pelicanparts.com/uploa...1421259805.jpg
http://forums.pelicanparts.com/uploa...1421259828.jpg
http://forums.pelicanparts.com/uploa...1421259848.jpg
http://forums.pelicanparts.com/uploa...1421259867.jpg
http://forums.pelicanparts.com/uploa...1421259926.jpg
http://forums.pelicanparts.com/uploa...1421260058.jpg
MichaelB 01-14-2015 11:21 AM
Well done. Bravo. Looks like it will be right on when done.
kennykimk2 01-14-2015 11:48 AM
looking good Dave. Let's catch up soon.
nvr2mny 01-14-2015 11:51 AM
Nice!!
flyn-hawn 01-14-2015 03:30 PM
Thanks Kenny! The car will be for sale when it's done as I have my IROC project waiting in the wings. If you know of anyone let me know.
Dave
jittsl 01-14-2015 03:31 PM
Loving it.
kshafer1 01-14-2015 03:34 PM
Looking great. Hope to see it in person soon!
SD Swede 01-14-2015 04:04 PM
Making San Diego proud...well done Dave. Now, get that paint on!
kennykimk2 01-14-2015 07:09 PM
Rs
Dave
Dave,
Let me know, when your car is done. I want to check it out.
SpyderMike 01-14-2015 07:45 PM
Where did you source the hood from? Nice project!
flyn-hawn 01-14-2015 07:49 PM
Dave at TRE Motorsports in L.A.
SpyderMike 01-14-2015 07:54 PM
Thanks...are you happy with the fit and quality? It looks like a nice piece.
flyn-hawn 01-14-2015 08:49 PM
The first one I bought they had had a problem with the mold but they did not find out about it until they had made some, mine in particular. They fixed the mold and I exchanged it for this one which fits really well for a fiberglass piece. The only problems with this style is you can't really massage the part without it being visible later. There is a tiny bit of curve running alongside the fender on the right side. I guess you could run a tiny bit of filler (bondo) down the side and then tape it and over lap the paint an inch, or half an inch under the hood. But definitely not something you could easily do fiberglass work on.The other problem which is my fault, I had them run the balsa stringers for a center fill/thru hood fuel tank and leave a gap in the balsa where I would have cut the hole, but I changed my mind and am going to offset to the left and forward not center where they stopped the stringer and left an open area. Here again that is not their fault but it would be real difficult to try to address that now.
Here is a picture of my other project and where I will put the fuel fill on the SC.
http://forums.pelicanparts.com/uploa...1421297318.jpg
http://forums.pelicanparts.com/uploa...1421297339.jpg
http://forums.pelicanparts.com/uploa...1421297351.jpg
http://forums.pelicanparts.com/uploa...1421297364.jpg
SpyderMike 01-15-2015 09:04 AM
If I understand correct - the issue creates an uneven gap on one side? both sides? Do you have steel fenders or fiberglass?
Very nice looking project there.
flyn-hawn 01-15-2015 09:30 AM
Yes an uneven gap, I will probably just block down that side and add a little more material on the fender. Yes FG fenders, I had to lengthen those on the door side because the gap between the fender and door at the cowl area was more than I liked. I just ground down the inside and layed some cloth and then some mat on the backside. flipped it over and added my father in laws special concotion on the front sideand am now in the process of gapping the fenders. gapping =sanding, grinding, dust, mess, itchy, etc., etc. You can see a lighter area at the edge that is the material that was added. Look at the far right of the fenderand you can see alot more was added there to get the gap down. There was probably an inch more material but its been ground away and really close to being there now. Now it is all sanding by hand and then fit check resand fit check sand more etc.
http://forums.pelicanparts.com/uploa...1421342784.jpg
SpyderMike 01-15-2015 11:56 AM
thanks for the details...knowing what you know, would you recommend the TRE product to someone looking to go down that path? If you don't care to post the answer, will you send a PM? I am in the process of part selection soon.
flyn-hawn 01-15-2015 12:14 PM
No I would absoulutely recommend that hood. It is far and away the best fitting FG part on the car out of the box. Everything is fitting pretty well now but you can't just bolt most pieces on and expect great finished results.
SpyderMike 01-15-2015 12:36 PM
thank you.
theiceman 01-15-2015 12:53 PM
did you powder coat your engine tin work or is that just spray paint ?
looks very nice.
flyn-hawn 01-16-2015 09:30 AM
Just got my seats and dash back from upholstery, still doing door panels, new tool roll, visors and misc. stuff. Since I long ago got rid of AC I asked him to fill up the center vent area while he was at it.
http://forums.pelicanparts.com/uploa...1421429187.jpg
http://forums.pelicanparts.com/uploa...1421429200.jpg
http://forums.pelicanparts.com/uploa...1421429210.jpghttp://forums.pelicanparts.com/uploa...1421429305.jpg
