Electrical problems after dead battery
My battery went very dead a few weeks ago because the trunk was left open for an extended period of time. Once I got the battery to hold a charge and get fully charged, the car has had some odd electrical issues.
The CDR-220 radio stopped working entirely and the automatic click to open or close the passenger door window stopped working. But the window would go up and down, just not automatically. This is in my 2000 Boxster S (same radio as the 996). Then after a couple days of driving, the window miraculously started working again. Then after a few more days, the radio will now actually turn on. But the buttons are not functioning 100%. Like two of the 10 station buttons would not do anything on FM1, but works fine on FM2 and AM. As I pulled in to work, it now seems like they were all working. The balance and fader buttons seem off too. What gives? Will it all fully come "back to life"? Are there electrics in the engine that might not be working 100%? So odd. I read a bunch of posts about people who said their fuse in the back of the radio blew after a battery went dead. I was assuming that was what happened to mine. So I was in shock after a few days that the radio is "curing itself" which I believe be somewhat impossible. Yet it happened right in front of me. Didn't get abducted by aliens though. .. yet. |
I assume that you started the engine by "jumping", in which case once the engine started the battery was so low in SOC that it would not play its part in regulating the alternator output.
That would be much like disconnecting the battery with the engine running which often results in the alternator voltage output "going into orbit", voltage spikes as high as 30 volts. Electrolytic capacitors, used throughout the car's electronic componentry, develop leakage at excessively high voltages, some will "heal", recover, some will not. It's NEVER a good idea to jump start a car with a dead, fully dead, battery. Good luck. |
Thanks for the thoughts! Actually, no jump start. I charged the battery with my charger. It actually wouldn't first take a charge at the 10A setting. I had to put it to the 2A for a long time and it finally fully charged. Then I started the car with the fully charged battery.
That does sound serendipitously weird. I usually had to enter a security code into our non-porsche radios if the battery was changed/disconnected (or died) and I had to reset/reprogram the wireless keys. Nothing ever came back from the dead like that for me.
I do know that sometimes if the voltage is less than optimal you can get some ghosts in the machine - just enough to do some strange things. Are you able to reprogram the FM1 stations now?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Still here
Replace the battery.
It's not going to last long anyway. |
I will check if I can reprogram.
Yes, I initially thought it wasn't working because it needed the code - which is in a folder in the house. So I first ignored it. Then I got the code card and went to put it in. That's when I found the radio was dead. It wasn't even asking for the code. I searched on line and found references to that back fuse blowing. So I ignored it for a second time. Believe me, I want to think I just missed something. But, I'm not a novice to working on cars! This is odd. And the crazy thing is that I wouldn't have known anything changed, except my wife drove the car yesterday and told me the "radio was working oddly." I was shocked because it wasn't working at all. And here is the last tricky, odd thing. I NEVER put in the code! Last edited by Jay Laifman; 01-14-2015 at 10:17 AM.. |
Member 911 Anonymous
DO you have your owners manual?
I recently had a new battery installed in my wife's CLK320 and the wrench had to reset the auto window feature by holding it in the up position for 3-4 seconds after it went up. He said allot wrenches do not know about this feature so many have auto windows that do not work because of the lack of the reset procedure.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Let me add these: When I tried to charge it at 10A, after about an hour or so, the charger would read that there was a fault and stop charging. I tried this a few times. Then I put it on 2A and it chugged along for a day or two and then indicated that the battery was in fact "FUL" - which it says on a complete charge. That said, when I do start it, it seems like it might not spin as fast as it used to. Can't say for sure though. So I'm not so sure there isn't something wrong after it discharging so much. But I don't know for sure. I'm looking forward to any information pmax provides.
Disregard me if you did this, but did you check the voltage with a meter and verify the fluid level was alright?
Take the battery out and have it tested at a FLAPS of AAA. Just to remove the battery from the list.
Still here
It is a 911, right ? Quote:
The fact that it doesn't hold a charge at 10A is telling. Last edited by pmax; 01-14-2015 at 04:30 PM.. |
Also, connecting a reasonably good low SOC battery in parallel works to "fool" the smart charger. "..not spin as fast.." Give it time, your car's alternator/VR system will raise the SOC above what most chargers will do, certainly so for a charger in the short term. Battery chargers go into float mode once the battery reaches an "acceptable" SOC, your car's system just keeps on producing ~14 volts, provided it can (RPM + load), regardless of battery SOC. That's why it is not wise to use the car's system to repetitively recharge a dead battery, it can/will eventually boil the electrolyte away. |
Acid leaks results either from a cracked case, or from boiling the electrolyte. The latter generally only happens when the VR has failed and is overcharging the battery. Last edited by wwest; 01-14-2015 at 04:43 PM.. |
Will... what about clutch popping?
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
A "smart" battery charger will quickly detect that it must raise the charging voltage beyond a specified design level to force a 10A charge rate into a fully discharged battery. |
Same problem, if the SOC is good enough that the battery accepts an alternator/VR dictated charge rate it WILL boil the electrolyte. Repetitively doing so without solving the core problem and the electrolyte will get down to.....
Not saying that we ALL haven't done either or both quite satisfactorily at some time or another. Just not, hopefully, multiple times on the same vehicle/battery. Not always possible to do it the RIGHT way. |
Besides discussing all the theories and "possible scenarios" I would do a couple of simple MEASUREMENTS with a DVM:
- voltage with ignition on and engine not running (connect meter to battery poles) - same while cranking - same while engine idling - same while reving engine to ~3k If you have access to an oscilloscope and are able to measure ripple while the engine runs that would be a plus. Then report back edit: didn't realize this was a 2000 Boxter. The alarm control module stores Vbat failures as a permanent fault code. And so do some of the other control modules such as DME, TCD, etc. The windows also have its own control module. Your best bet is to hook the car to a PST-2 or PIWIS and reset these codes and take it from there. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 Last edited by ischmitz; 01-14-2015 at 09:11 PM.. |
Eng-o-neer
Everyone with a battery should own at least one Battery Tender Jr
Put it on every time you park the car in the garage. |
