s_wilwerding's Avatar
Source for engine shelf
As I am planning on doing the chain tensioner update this winter, I need to remove the engine shelf tin. I noticed the other day that one of the pieces is rusted through. I'd like to replace it when putting everything back together, but I can't a find a place that sells the engine shelf.
Has anyone replaced this? If so, did you buy the pieces or have them made?
Thanks.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 10-21-2002, 06:32 AM
Send a message via AIM to Oldporsche
Cool
I have access to a very talented welder/heliarc expert. He patched up my tin. Afterward I carefully ground the upper surface weld(the area you can see when the lid is opened), and took it to a local zinc plater. They threw it into a a batch of items they were already processing. When I got it back from them I painted it up with a little zinc chromate primer and painted it black.
It looks great.
Good luck,
David Duffield
Old 10-21-2002, 06:50 AM
Crusty Conservative
silverc4s's Avatar
Or, you could try www.partsheaven.com in Hayward, CA. They are the reigning source for used Porsche particles...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-21-2002, 07:13 AM
