H.G.P.'s Avatar
How does my Goetze oil rings (with the spring inside), slide onto the piston?
I have Goetze rings,
1. Does the oil spring expand with the oil ring when it's being installed? (I can't see a "break" in this spring like the other rings)
2. Does the spring "roll" down with the oil ring?
I don't quite see how this oil ring with inside spring installs?
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 01-11-2005, 08:15 PM
CBRacerX's Avatar
Spring does have a "break", and there is a wire inside. Just find the break, spread apart and install _with_ the ring proper.
Hint: Install so that the break in the spring and the ring gap are 180 degrees apart.
Chris
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-11-2005, 08:26 PM
H.G.P.'s Avatar
Chris
I see it, thanks! Wow is that small.
1969 911 E Coupe
Old 01-11-2005, 09:41 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
You can also take the 'spring' out, place it in the land, then place the ring on top. Make sure the spring and rings gaps are not alligned.
I knew these rings would come in handy one day.....
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 01-11-2005, 09:44 PM
CBRacerX's Avatar
I think the last engine I did I used the method that Charlie described. Just don't spread those rings too far apart!
Chris
Old 01-12-2005, 10:02 AM
