I've read about leakdown tests being done but will an old fashioned compression test give me similar results (plugs out crank the engine on the starter) If so what sort of readings should I get?
3.2 Coupe Last edited by Nathan M; 10-22-2002 at 10:18 AM.. |
Per BA's recommandation, compression test should be done prior to leak down test. I remember my readings were between 150-170 when I did mine couple years ago. Leak down test is to find out where's the leak for the low compression reading cylinder.
Hope it helps. Andy '87 Carrera |
Author of "101 Projects"
Search the archives - plenty of info on this...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
