Fan Housing Strap removal
If I learned anything form this forum is ask first before you do something stupid and costly. Have to replace the alternator and its completely out with the fan from the 1988 cab 911.
All that is left is the fan strap. I want to paint it and can see no logical way to remove it.
The bottom of the fan belt is flat and as it rotates it get locked it. Just checking with the group on how to remove the strap before something costs me big time . Your help appreciated
Old 02-08-2015, 01:27 PM
Send a message via Skype™ to Porboynz
It bends
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 02-08-2015, 09:05 PM
If you are absolutely sure that you want to paint it then I would recommend carefully masking it up in place and painting it there. Reason for this is that as already mentioned to remove it you have to bend it which will ruin the paint job.
Good luck
Ian
Old 02-09-2015, 10:41 AM
And when you put it back, it will scratch.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-09-2015, 03:39 PM
Discseven's Avatar
REK... removed mine on '85 and will confirm what guys have already said... needing to bend it and it scratching on case. Think Ian's suggestion to paint it in place is way to go with this.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 02-09-2015, 03:55 PM
pors1968's Avatar
When dry put some masking tape before put it back.Easier when dist is out.But dont take the distr out if you dont know to ajust it.
Old 02-09-2015, 03:58 PM
