Another cam timing question
hey all
I am doing some baselining of my engine before i rip her apart for a head stud reapair. Up until this point my car has been running spectacularly. With a lot of Jump , no oil usage and great overall performance. I have a stock 3.0 lite 78 SC . I did notice the case had been split bfore i ever got her so maybe a little more investigation is in order. The reason for this post is as follows. I have done my valve overlap and for a 78SC it is suppose to be 1mm or 40 Thou. when i check it i consistently get 25 thou. I checked the intake of both cylinder 1 and 4 and get the same result. i even went as far as setting up a second dial indicator on the opposite cylinder/piston to measure TDC accurately and the results are the same. i also verified the valve clearance before i started on both sides and also checked the cam partnumber a it is stamped on the front. I guess my existing cams could have been reground and i would not know that. is there any particular reason anyone would set this up intentionally this way ? Anyway just lookin for input. i think when i put it back i will set it up at the required 40 if i cant come up with a resonable explanation.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Cam Timing..........
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
perhaps chain stretch or maybe even sprocket wear. more likely the chains.
if they stretch the valves would open later making the lift at overlap a smaller number. this would retard the cams giving you better bottom end. or, maybe they were set that way on purpose. porsche moved the cam timing around on teh SC so check the specs for other SC's, maybe they were set for another year,
Fleabit peanut monkey
I will scan Anderson's book when I get to the shop to see if I can find the info. My gut feel is that it has been adjusted to those specifications because it's spot on.
1981 911SC Targa |
yup i was think it was set there intentionally also since both sides are identicle.
i am going to pull the chain when i get there and check it for stretch. there may be a way for me to indirectly measure IMS gear wear also.
bob, that is what they did. i did not remeber the years and the specs
advanced, retarded then in the middle. so someone (someone like me) might have changed the timing to one of the others years.
