911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Shift coupler
I've replaced the ball cup bushing and the shift rod bushing with the gear in neutral. Now I'm thinking: is it wise to rebold the shifter and then remove the coupler with the shifter in first gear or should I remove the coupler right now with the shifter out of the car (in neutral)?
Thanks ,
Kees.
Old 02-10-2015, 01:05 AM
Brew Master
cabmandone's Avatar
As long as you mark the shift coupler and shaft I don't think it matters. I left my car in neutral, marked the coupler and input shaft, rebuilt my coupler and reinstalled lining up the marks and had to make a very slight adjustment when finished to get it shifting a little better.
Old 02-10-2015, 06:25 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 assuming your coupler is slop free then simply mark and replace in same position, you should be golden.
'85 Carrera Targa
PCA/POC
Old 02-10-2015, 09:52 AM
