Recommedation: Shock absorbers.
My 1987 911 has Boge struts. Shock brand options include; Bilstein, Koni, and Sachs. Recommendations for "street" use please, and there appears to be a good sale price on Sachs.
Old 02-13-2015, 08:54 AM
I put the Bilstein HD's on my '87 last year.... love them. I nice upgrade from the original Boges I had on there.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-13-2015, 09:51 AM
tobluforu's Avatar
I have Bil HD, wish I would have stuck with Boge. If street car, Boge if you can get them.
Old 02-13-2015, 10:01 AM
Reiver
Reiver's Avatar
I use Bil HD's on the rear and the stock sachs/B up front and that is a good for street.
When guys say 'upgrade' they mean stiff...not nec good for a street car as the originals are stiff enough.
Put Bil sports all around and lose fillings on a bumpy road.
De Oppresso Liber
Strength and Honor 5th Legion
Old 02-13-2015, 11:11 AM
My '75 originally had Koni's. About two years ago, I replaced the originals with new Koni red shocks and strut inserts. I've been very pleased with them. The originals were worn out, and the new ones are not too firm.
One thing to keep in mind though. The original Koni shocks in the rear were not gas pressure, but the new ones are. So it raised the rear of my car up some, and I had to re-index the torsion bars. I believe many report the same kind of thing when going from the non-gas Boge to the high gas pressure Bilstein HD shocks. I could see the same thing happening with the front struts as well, if you use Bilstein HD. Just something to keep in mind.
Since your car is newer than mine, adjustment of the rear height may be a bit easier since your rear spring plates are adjustable.
Old 02-13-2015, 11:19 AM
I wouldn't categorize my "upgrade" as stiff at all. Very nice ride on the street. Not jarring or harsh.
I want to say the Bilstein HD were the factory sport alternate to the Boge's.
Now the Bilstein sports are another story. Those are quite stiff for everyday street driving.
Old 02-13-2015, 11:20 AM
BER BER is offline
BER's Avatar
I run Bilstein Sports on the '84 Carrera and love them. The Sports complement the larger t-bars that I am running on that car. The '77 911 has Koni struts/shocks and they work fine. When it's time for new shocks/struts, I'll replace them with the same setup I have now.
You say you have Boge struts on the front of your '87. Are you sure a Bilstein strut cartridge will fit into a Boge strut housing? My front Bilstein struts require a roll pin that is inserted into the base of the strut housing. I may be mistaken, but I don't think the Boge strut housing has the holes for the Bilstein roll pin. Again, I may be wrong on this...but it's something you should check.
The rears should not be a problem since they are regular shocks back there.
BER
Old 02-13-2015, 11:32 AM
ganun's Avatar
I put Boge / Sachs on the rear of my 87 and do find them a bit soft, strictly street, wonder if the B HD are just a bit more firm?
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 02-13-2015, 11:36 AM
I have Boge struts on my '74 911, upgraded to Bilstein HD last year, they are firm, but not uncomfortable, going to Bilstein Sport in the rear this year, and if I can find Bilstein struts without breaking the bank, I've also got new Bilstein sports for them. Currently wanting to go to coilover, but I can't raise the spindles on Boge struts much.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 02-13-2015, 11:55 AM
Follow-up: Are there quality issues, e.g. life, between these three choices? The non sale prices advertised for the Sachs shocks are considerably higher then the Bilstein or Koni shocks.
Old 02-13-2015, 11:58 AM
I think all three are equally well regarded in terms of quality. I've had Bilsteins and Koni's on other vehicles and they are well made. KYB's for example would fall in the lower quality category.
Old 02-13-2015, 12:18 PM
wrxnofx's Avatar
My struts are Boge in my '87, like yours. The PO swapped out the standard dampers for Bilstein Sport inserts. I'm happy with them but don't really have a comparison.
The Boge struts are versatile because manufacturers make different inserts for those struts. Here is an example.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 02-13-2015, 02:32 PM
douglas bray's Avatar
I was fine with Bilstein HD inserts in my Boge struts and Bilstein HD's in the back when all my T-bars were stock....Now, OMG that isn't the case.
Old 02-13-2015, 06:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I had old Bilsteins HD all around.
Steve Alarcon of Johnsons Alignment in Torrance recommended I go with HD fronts and Sport rears for "Aggressive Street" use.
Wow, what a difference, it will ride about 1/2" higher due to the newness of the struts/shocks.
If you just want it for street go with HD Bilsteins all around.
Note, when tightening the gland nuts for the fronts, tighten the heck out of it, put your foot in the wheel well and use a cheater bar extension, you'll need it. A good guide is count 3.5-4 threads up, that is how many threads should show, it should be snug enough. Also use some BLUE loctite for insurance. The Bilstein tool is crap, it is too loose and the nuts are too soft, after 120 ft lb, the tool will fail the torque needs to be 184 ft lbs. Pipe wrench is what Steve uses
'85 Carrera Targa
PCA/POC
Old 02-13-2015, 08:47 PM
Vintage Motorsport
RichardNew's Avatar
Here's an article I did about shocks last year. No one is talking about spring rates. You springs or torsion bars are a key factor in shock selection.
Richard Newton
Old 02-14-2015, 05:14 PM
Thanks for your valuable comments. I decided to replace with the same Boge inserts and rear shocks. For street, I go with the factory provided equipment.
Old 02-14-2015, 07:33 PM
Bill Verburg's Avatar
Yes, Bilstein quality and durability are head and shoulders above most if not all of the off the shelf alternatives
Additionally the upside down design of the shocks when used in a Bilstein strut reduces unsprung weight.
hd front/sport rear is a nice setup
It can be made even better w/ custom digressive valving
Bill Verburg
Old 02-15-2015, 06:01 AM
Cars and Cappuccino
tdw28210's Avatar
I just put Bogue in my '87 and Bilsteins in my '85 FFA (Factory Fat-Ass) M491. I can tell you that I will be putting Bilstein HD's in the '87 after I get my plaid interior project done. Not sure if the Bogue's are just that way, but honestly, they seem rough, while the Billy's are firm, yet supple.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 02-15-2015, 06:17 AM
