ROW H4 headlamp leveling system
In the late 1980's and early 1990's (1987-1994?) 911s and turbos in certain markets could have H4 headlamps fitted that had a vacuum operated leveling system, controlled by a dial on the dashboard. I would like to see how the vacuum dashpots are integrated with the H4 reflector assembly, so if anybody has one of these lights, or has a photo of the back side of one, I'd like to see it.
I'm curious as to whether or not this system could be adapted to a regular H4 reflector, or if the reflectors themselves are substantially different. Thanks, JR |
A year or two back Blackbyrd had a set for sale and posted pics in his thread
I think that maybe I'm dreaming.. |
Here are some fotos of the headlight... ![]() ![]() ![]() I had sort of resigned myself to picking up yet another set of H4 headlights (they are available new for around 400 Euros, the option number is M605 headlight levelling option (or vertical aim control) switch is 911 631 231 00, light is 911 631 023 00 near as I can tell. I would be delighted if someone knew what the mods are to the headlights, it doesn't look too complex, but there appears to be some specialized parts that might be hard to fab up. I was also hoping to find (in Europe) some headlights out of a wreck where I could just liberate the special parts and fit them to one of my good H4 sets. Any info appreciated... Dennis |
Just like to get this thread going, but where can I get the reflector for these headlights. The only ones I see online are for the ones with the rubber bushes on them.
Cheers Alex |
Hi there, it took me several years to collect all the parts for this option....and my assessment is that you can't fit them on to the standard H4 without some serious modification plus a whole pile of custom parts.
I amazingly was able to trade my H4's to someone who had a set with the vacuum actuators which made the whole thing work for me. Look, anything that is made can be copied, certainly some of the plastic parts might be able to be printed using a 3d printer, but I worry about their strength and durability especially with the heat from the H4 so close. I would also note you need the vacuum reservoir (still don't know where exactly that sits or what bracket it uses to hold it in place), plus you need a vacuum fitting on the power brake booster with a small port to feed the system, plus the check valve for the vacuum tank. All those parts are 924 or 944 parts. The piping is an odd size.....I just ordered two of the longest ones in the parts list - Porsche still carries them and I think it is about $20 for a few meters of the stuff - so it should all come together. M605 was not a common option - but check the 964 market, it seemed to be more common on those cars and is basically the same system from what I can tell. ![]() ![]()
Reviving thread in case anyone has more info. I found a pair of these off a 964 and since I am looking for H4s to fit my US '89 Carrera, thought it might be interesting to refit. However, does anybody know what might be involved in fitting a US car with the vacuum lines, reservoir, and electrical to actuate? And if so, can I use the headlights before I refit the other bits?
I have the complete system, yet to be operated as the car is just getting into the final stage before engine start up.
The system is fully pneumatic, no electrics and basically it replaces the brake booster check valve with one from a 924 which has a take off for a small hard plastic pipe, around 1.5 mm ID. That gets routed to the switch on the dash after running to a vacuum reservoir which tucks into the big hole on the PASSENGER side of the trunk before routing to each of the headlights. This routing follows existing paths for wiring and windshield washer lines. The hose is largely hard plastic with custom formed rubber elbows and some rubber hose where it goes onto fitting and such. If you check PET, you can see the schematic of the piping and the lengths. My plastic pipe was split and not in good shape so I just bought the longest length available from Porsche (PET gives the lengths), paying a price so low I merely screamed - i recall it was the pipe for RHD drive cars and just cut all the pieces from that. Here is the reservoir and headlight as built just for reference. ![]() ![]() Let me know if you need any more help... D. |
