Tcrate's Avatar
Altitude Control Unit
Does anyone know what this unit does. I pulled my drivers seat today and noticed this unit underneath. I don't believe it was connected but I am not completely sure whether it was or not. Lets just say when I went to remove the wire connection it either was not connected or the connector was not tight. I believe it should be left disconnected but I am not sure.
Part number is 944 606 151 00 picture attached.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
1973 Mustang Mach 1 351C
Old 02-14-2015, 06:44 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It adjust mixture on extreme altitude change. If you are not in a mountainous area then I guess you can leave it unplugged???
'85 Carrera Targa
PCA/POC
Old 02-14-2015, 06:59 PM
Tcrate's Avatar
Ok but sounds like plugged or unplugged it should not matter. I do have a different chip than stock in this car would that change anything?
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 02-14-2015, 07:12 PM
Plug it back in. It is part of the computers input, no downside if plugged in.
Old 02-14-2015, 07:52 PM
Diss Member
Quicksilver's Avatar
It is a simple on off switch that flips at 3500 feet (or somewhere else in the 3K range...).
No reason to disconnect it simply because you aren't apt to remember when you go on that one drive through the mountains.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-15-2015, 07:56 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
As Wayne said it's a simple switch that closes above a certain altitude to compensate for the lower air density up there.
The DME will lean out the mixture when this switch is closed. However, this is done through software and the switch is read through one of the A/D converter channels. So if the chip maker has enough skills this could have been be disabled with an aftermarket chip. Not that there is a reason for it. Only way to test would be to simulate the switch closed and check that fuel signal changes slightly.
So I'd connect it back after verifying the switch is open while you are close to see level.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-16-2015, 02:16 AM
I had a thought once that maybe this switch could be tested by putting it in a vacuum bag and pulling a slight vacuum? Has anybody tried this, or want to (easily) defeat my atmospheric knowledge?
Chuck.H
'89 TurboLookTarga, 391k miles
Old 02-17-2015, 06:21 AM
