Enthusiastic Newbie
Verax's Avatar
Question Clutch cable disconnection from pedal cluster
I'm trying to disconnect the clutch cable from the pedal cluster and I can figure out how this connection works. I have a few ideas on how to get it disconnected but am not sure I could 'undo' what I have in mind if you know what I mean.
Does anyone know of a tutorial that can show the correct way to disconnect the clutch cable so I don't end up destroying it.
1974 Porsche 911 Targa turbo look with '81 3.0L Engine
Old 02-20-2015, 05:27 AM
Start by disconnecting it at the other end.
JR
Old 02-20-2015, 05:42 AM
Enthusiastic Newbie
Verax's Avatar
Unhappy
Unscrewing it is really the only way
Old 02-20-2015, 05:51 AM
Watch out for a grossly worn connection like this. This was how I found the clutch connection on my 33 year old, 200K mile car whose clutch cable connection had never been apart. I had to dremel it to get it apart (but I was replacing the cable anyway.)
Old 02-20-2015, 05:58 AM
Tired Member
DaddyGlenn's Avatar
There are plenty of threads on this. Do a search.
You have to release the pressure by disconnecting the cable at the rear. Then pull the carpet back to get at the pedal connection in the tunnel. Release the clevis and your are done.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 02-20-2015, 05:59 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, you do not want to be fighting the pressure plate to gain slack to remove the clevis at the cluster.
Sorry mate, it is the only way, if you want to save the cable short of cutting the cable if you plan to replace the cable that is.
'85 Carrera Targa
PCA/POC
Old 02-20-2015, 06:08 AM
JTL JTL is offline
JTL's Avatar
The pedal end clevis connector is in a tight spot next to the gas pedal going into the center tunnel. Its a bit of a pain. Just unsnap the clevis and push out the pin. Putting the clevis connector back on is even more fun - ha.
Cheers, Jt
-84 911 targa
Old 02-20-2015, 06:30 AM
Senior Member
Jdub's Avatar
Once you have done it one time, you will see what we are taking about. But the money item in this thread is the pic above of the clutch pedal "ear" and the terrible condition it gains once the small, round brass bearing "ring" dissolves to dust over time. You will need to remove the entire pedal cluster and have that area welded and re-drilled to the correct size. I caught mine in time, and have at least one spare brass bushing in my toolbox for the next go-round.
Cheap insurance.
'78 Targa in Minerva Blue
Old 02-20-2015, 08:36 AM
