How will the Cali guys with CIS pass smog in the future?
I got thinking about California P-car owners with '76 - '83 cars and CIS-- as we all know both Bosch and Porsche aren't supporting CIS any longer. No new parts, just rebuilt. I have no idea if this will ever be an issue or not, but am curious. If I have understood correctly, no car newer then a '75 gets a smog exemption in Cali, so CARB requires the induction to be stock, and if parts get scarce some years down the road, then what? Its pretty unreasonable to render an entire automobile un-registerable just because its old enough to have NLA parts on it-- especially when modern (more efficient and less polluting?) induction options exist.
Not trying to start a political battle about the great state of California, just a guy in Norway dreaming of sunshine and trying to learn something.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Metal Guru
CARB's ultimate goal is for everyone in the state to drive an electric car or ride a horse. They would prefer that not a single vintage car exist within it's boarders.
It's going to take some serious intervention on the part of the car hobby to change this.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
gearhead
There's a solution. Aftermarket fuel injection suppliers can get their parts CARB certified.
They used to have a rolling thirty year exemption. Ahnold the asshat got rid of that. Jerkoff.
CARB certification isn't cheap. Best to get another exemption or hobbyist bill passed.
I will use a FAF when I am dying of thirst
Doesn't the state issue something called an SB100 for project cars? Maybe that is the way to go?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Free minder
Isn't there an age limit in CA where cars are no longer subjects to emissions, like in any other states? Even in bleeding heart liberal Massachsuets, my 78 is now exempt to pass emission. Which is great because I am running 74 heat exchangers and not cat...
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Cars 76 and newer here need to pass smog. It's not a "rolling" model year exemption, and SB100 is for kit cars.
Air Cooled
Problem with exemptions is the decade from 76 to 86 was the birth of emissions controls, and those cars are the ones that my state of Colorado is most strict about. I have to do emissions, at California's level, every-single-effing-year!
This is why I spent $2k on a custom exhaust with new tech dual cats, that also makes it faster and lighter. It's still a major pain in the a$$ to have the former/future felons that work for the state, man handle my pride and joy every year.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
you have to cheat. most smog guys dont know what is stock on these cars. at one point i didnt even have a o2 present, that gave the guy a small headache. finally he gave up and just passed me. most premufflers look like a cat anyway. the cheat part involves disconnecting the o2 and hooking up a AAA battery at 0.7v connected to the o2 connector. that leaned my car out enough to pass without elevating the HC too much
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Diss Member
Not really a question. A "72 backdate" was built using a car with a VIN number. The year of the original car will always be the year of the car. Period.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I say if the parts become obsolete then we should be exempt. But that's because I think smogging my 78 is hideous and I would love to get some SSI's and pick up some usable h.p. and a nice sounding exhaust.
jtp911 |
CIS is a fine, stable system that should carry our cars forward with little or no problems. Tuning is important, of course; but the biggest problem that I see is lack of technicians who truly understand CIS. A couple of inspections ago the smog shop that I use told me that my '82 SC ran cleaner than a five-year-old Honda. If the car has its original, functional equipment it should pass.
Let's not forget that ignition, with vacuum controls, also plays a part, as does having a smog pump and EGR system ('76-79 models) in proper working order. Those items can cause a fail result even when the CIS is working/adjusted perfectly.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 02-23-2015 at 10:40 AM.. |
On a side note Joe, that's actually quite possible. In my backdated car, (a '78 SC to RS hot rod) I have a '84 3.2L ROW motor, running SSI's and a custom built, great sounding, exhaust that incorporates a CA approved cat and a Magnaflow muffler. It is bolted straight up to the SSI's. This setup was approved and smogged by the referee when I brought the car in from out of state. Due to the engine swap the ref was the only one who could approve. You can PM me if you want more details. Not hard to do at all. In addition, between the 2 year cycle, I usually unbolt that custom muffler set up and run an M&K. Takes about 30 min to swap out.
Pete Andersson Pinstriped Early 911 Club |
All this will just raise the value of earlier cars even higher.
Hugo |
Still here
I really believe a cleaner running engine is a better running one and more reliable in the long run. Quote:
Keep the Shiny Side UP! Pete Z. |
Under the radar
Not directly related but I just found out that in CA cars newer than 2000 AREN'T SMOG TESTED any more.
At the smog test station they plug in a tester to the OBD port. No codes and it PASSES!!!!! REALLY?
Yeah, I just had our 2005 minivan smogged and there was no sniffer - pure OBD2 readout.
Now if I could only get the title to one of my cars...(mistake on VIN, corrected, 3 months wait from the DMV.... which is swamped by the new mandate to give illegals driver's licenses, according to the facilitator I used... slowww) PS: I should point out I didn't sell the SC because it wouldn't pass emissions, but because it wouldn't pass visual. That car actually passed Cali SMOG for 10 years with gutted catalytic converters (which I had no clue about until I took them out 10y later). Last edited by Deschodt; 02-23-2015 at 01:44 PM.. |
