76 and 84 cam housings interchangeable?
Just wondering if they swap. Serial numbers identical till last two digits. Any concerns with a swap?
If you have an extra one lying around... A Po buggered mine up... Last edited by gliding_serpent; 02-25-2015 at 06:14 AM.. |
3 bearing and 4 bearing. different size bore. would have to use the related cams, but they would interchange.
The 76 is no good then.
So i am assuming 3.0 to 964 would be a direct swap allowing use of original 3.2 cams? Last edited by gliding_serpent; 02-25-2015 at 06:55 AM.. |
Schleprock
Yes the four bearing cam housings are all the same generally speaking for 3.0 SC, 3.2 Carrera and 930/3.3L Turbo (including 964)
I may have a good spare housing in my collection. I'll take a look for you.
Kevin L '86 Carrera "Larry" |
There is 78/79 that used 901 part casting but are 4 bearing Check the date stamps
Bruce |
