Caveman Hammer Mechanic
3.2 SSI swap.
Like the title says, I am in the process of installing SSIs and a M&K muffler in place of the stock stuff, got all the gaskets and stuff to include new oil lines, from Elephant Racing.
Got all the old stuff off, no broken studs or grief, about 2 hours , all told. Started to fit the Elephant Racing Universal Crossover pipe to start the party going. Seems the flywheel sensors are in the way, no amount of fiddling or tweaking will allow this to fit. Gonna have to go old school, breaking out the die grinder, TIG welder and hillbilly fab techniques. ![]() More to follow
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Make America Great Again!
Very interested in the outcome!
Question, are the insert into the head the correct size or they smaller to fit the 80/83 SC. Reason I ask is I have seen a couple 3.2s with SC size inserts.
I know there was C2 SSI s with thick flange and no insert, just flat surface. Bruce |
SSIs are thick flange and insert into the head. Had to add about an inch of tubing and do some hillbilly bending of the "Universal" tube. This is not plug and play. Used the TIG welder and some silicon bronze rod to heat/bend the tubing. Must have been under and back 75 times, tack weld, heat, add another tack weld to change the bend. All the while scraping, smushing, and dropping said gunk on my face, got all the new oil lines in, attached and torqued to spec. Now my supply of Pelican Exhaust studs, nuts and extra gaskets will be here tomorrow. Was actually thinking of using Titanium studs and nuts for the heads and fasteners with nickle anti-seize. Thoughts?
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-05-2015 at 09:53 PM.. |
abides.
I wound up grinding off the inserts and putting a light taper on the SSI inlets... kind of a pseudo-porting job. The SSIs sold for 3.2s do have correctly sized inserts for the 3.2 exhaust ports.
Graham 1984 Carrera Targa |
Well,
I have the SSIs installed, M&K muffler is cinched up nicely. Added 8 quarts of oil, did a test run for oil leaks, dry as a bone, sounded like a P51, WTF? Seems I left the O2 sensor port unfilled with either a plug or sensor. Found a plug from the trusty parts stash, NICE sound, I think it will loosen women and small children's bowels at full chat! Flicks: ![]() ![]() Still have to do the heater backdate and make a crossover pipe support since I cut the original off. ![]() Getting the exhaust stud depth was a study in patience, each side was off and on 4-5 times to get the depth deep enough to allow the Snap-On swivel 1/4" drive socket on an have a good angle and for the barrel nuts deep enough to all of full bite on the Allen wrench. More as the heater backdate goes forward. The good news is I have a supply of 2.5" "U" bends to allow modding the exhaust air plates, as well as enough SCEET tubing for a couple of projects.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-07-2015 at 09:15 PM.. |
Well,
Got it all buttoned up, plumbed for heat and stuff. Took it out for a lap of the Boulder Creek GP course, below 2k, it just rumbles along, 3k, it gets mad, 4.5k, it sounds like a ME109 going after a B17. At cruise about 2.5k it just motors along without much drama. Feels like the midrange picked up a little oomph, will see after driving for awhile. Something about the sound of equal length headers, sounds nice, liking the M&K already.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-08-2015 at 08:12 AM.. |
Is there a practical way to bring over the RH side header's heater box inlet over to the LH side and join with a 'Y' to have one inlet as the original system had?
Like anything, given enough time and effort, yes. With the M&K there is room to the rear of the car, not so much with a banana style muffler. Thin wall tubing and a TIG welder means lots of choices.
If you do bring the two ends back to stock 1 pipe inlet post your technique and results.
Thanks Griff |
disband
will you be going back & forth for smog testing?
ive got that M&K I got from a pelican in the classified and am looking to find the model name or number of the unit. im often asked about it on race weekends because im told it has a very unique sound compared to the other spec cars that have a wide range of exhaust set ups.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
M&K only lists one on their website, I think there are a series of versions though.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-09-2015 at 10:08 AM.. |
Re selected my DME fuel quality switch to the "0" position, 0 fuel correction, 0 timing adjustment.
I cannot believe you got all of the old manifold bolts AND studs out with out drama!!! Was this a case of skill and the right tools (which I know you have both) or has it been apart before....or just luck?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
disband
California car..... our taxes are high, but our exhaust studs are not likely to rust out on even a moderately cared for car.... a California 2.7 leaks enough oil that the ES won't rust a bit...
Aircraft mechanic, removed hundreds of aircraft systems, it a combination of torque, and type of movement, a slight surging of the torque. It's a feel thing. I read all the horror stories, and was careful, with the re installation I used nickle based anti seize. This is why I was wondering about titanium studs for the exhaust.
Go-Kart Mozart
Someone here did it. I remember seeing photos of just what you describe. IIRC someone modded the regular 3.2 hot air tube to work. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
i think i have the same set up on my 3.2 but my muffler is about half the length? i love it but my neighbors dont im assuming...
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
