Always learning
Correct torque value for M6 cv's
I've found m10 and m8. Can't seem to find correct torque specs for M6. Is it 30 pounds?
Always learning
Pics
That is an M8 fastener.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Fleabit peanut monkey
I just looked at my allen head sockets. I have a hodgepodge grouping. There are designations on them I don't understand.
1981 911SC Targa |
The size of the tool to turn the fastener does not dictate the size of the fastener. Your CV bolts are 8x1.25.
Doh. Thank you. I got wrapped up in the number on OP's socket.
1981 911SC Targa |
CV Bolts are all Grade 12.9 and the maximum recommended dry torque figures are as follows:
M10x 1.5 62lbs ft M8 x 1.25 31 lbsft M6 x 1.0 13 lbsft This torque will give a preload equivalent to around 80% of the fasteners yield strength. If you oil them with a 'standard oil' I would reduce these torque figures by around 25%. |
Always learning
Correct size
Oh okay. So the socket with HW6 (see pic) is in fact an m8? How confusing!
Okay I'll torque up to m8 specs. |
Know the basic......
Do yourself a favor and measure the fastener (bolt dia.) and the tool (allen). The HW6 is the designated size of the tool and has nothing to do with the size of the fastener. This also apply to sockets and wrenches. Tony |
So how to classify a certain bolt size? By the diameter of the threaded portion. Measure the threads on your bolts and they will be just under 8mm indicating an M8 bolt, regardless of headshape or wrench size. |
RETIRED
30 plus......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
