Always learning
Correct torque value for M6 cv's
I've found m10 and m8. Can't seem to find correct torque specs for M6. Is it 30 pounds?
Old 03-07-2015, 03:58 PM
Always learning
Pics
Old 03-07-2015, 04:20 PM
Jeff Alton's Avatar
That is an M8 fastener.
www.turn3autosport.com
Old 03-07-2015, 04:23 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I just looked at my allen head sockets. I have a hodgepodge grouping. There are designations on them I don't understand.
1981 911SC Targa
Old 03-07-2015, 06:40 PM
LJ851's Avatar
The size of the tool to turn the fastener does not dictate the size of the fastener. Your CV bolts are 8x1.25.
Old 03-07-2015, 06:46 PM
Bob Kontak's Avatar
Doh. Thank you. I got wrapped up in the number on OP's socket.
1981 911SC Targa
Old 03-07-2015, 07:04 PM
CV Bolts are all Grade 12.9 and the maximum recommended dry torque figures are as follows:
M10x 1.5 62lbs ft
M8 x 1.25 31 lbsft
M6 x 1.0 13 lbsft
This torque will give a preload equivalent to around 80% of the fasteners yield strength.
If you oil them with a 'standard oil' I would reduce these torque figures by around 25%.
Old 03-08-2015, 01:18 AM
Always learning
Correct size
Oh okay. So the socket with HW6 (see pic) is in fact an m8? How confusing!
Okay I'll torque up to m8 specs.
Old 03-08-2015, 04:04 PM
Know the basic......
Do yourself a favor and measure the fastener (bolt dia.) and the tool (allen). The HW6 is the designated size of the tool and has nothing to do with the size of the fastener. This also apply to sockets and wrenches.
Tony
Old 03-08-2015, 04:14 PM
LJ851's Avatar
I would be confusing if it was the other way around. If that 8x1.25 bolt had a hex head, it would typically be 12 or 13mm in wrench size. If it was a button head allen, it would be a 5mm wrench size.
So how to classify a certain bolt size? By the diameter of the threaded portion. Measure the threads on your bolts and they will be just under 8mm indicating an M8 bolt, regardless of headshape or wrench size.
Old 03-08-2015, 04:16 PM
RETIRED
Joe Bob's Avatar
30 plus......
2012 ML350 3.0 Turbo Diesel
Old 03-08-2015, 04:24 PM
