Suggest a shielded sensor cable grounded at both ends to eliminate signal noise potential.
The gap distance is critical to for a Hall Effect sensor set up for sideways detection.
1980 911 - Metzger 3.6L 2016 Cayman S |
The thread is related to monitoring flywheel sensors, which on early Porsches use variable reluctance sensors (AC pulse) and not Hall Effect (square wave).
Dave |
The nano was out of stock
The nano was out of stock, so I picked up this all in one unit from Amazon.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
