Charles Freeborn's Avatar
Tunnel throttle linkage bushing replace
Time to do them. Any suggestions on sequence?
Will pull pedal cluster at the same time and re-bush.
Thanks,
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 03-08-2015, 12:18 PM
83 911 Production Cab #10
JJ 911SC's Avatar
If these are not the ones you are talking about and can stomach $27 for 3 pieces of plastic... replace them.
Actually you might not even find them, I only find a piece of one.
901-423-227-00-M253
Who Will Live... Will See
Old 03-08-2015, 12:37 PM
JJ 911SC's Avatar
I also replace the Throttle Rod Coupling
901-423-227-00-M253; 1970 Porsche 911 T Coupe/Targa - Fuel System - Page 4
Old 03-08-2015, 12:49 PM
Those are them. All three new ones in hand. Throttle coupler done already.
Thx.
1972 914/4 Race Car
Old 03-08-2015, 02:05 PM
JJ 911SC's Avatar
Good.
Well to put the bushing in, you'll need to removed the shifter.
Since you are removing the shifter... How about a "shifter" up-grade (love to spend someone else money ).
Old 03-08-2015, 02:34 PM
Shifter is done too - stock at least. New cup and bushing made it work like new. Maybe a WEVO one day...
1972 914/4 Race Car
Old 03-08-2015, 04:16 PM
tshebib's Avatar
Be sure to check the weld on the throttle lever.
Old 03-08-2015, 05:00 PM
JJ 911SC's Avatar
+1, Had the same problem. Just could not bring myself to pay $65 for a new one...
Originally Posted by JJ 911SC View Post
My friend straighten the bracket, turned a new pin (from a 12.9 bolt), press it in and miged the bolt end to the bracket.
Crocked and wobbly:
Came apart:
The pin was too short to work with:
New pin pressed and welded
Old 03-08-2015, 05:13 PM
Nice job on the linkage. I think mine's okay, but we'll see when I dig in there.
-C
1972 914/4 Race Car
Old 03-09-2015, 08:26 AM
