SHould lights flash?
Hi All -
I have been going through every bloody system in my car this winter. I thought I was down to only one issue, until I noticed something last night - my headlights do not flash. When I pull the stalk, should they? (my car is a 77). All other dash controls, lighting, turn signals, high beams, etc - even the trunk lights - are unmolested and work perfectly. Should I be able to flash my lights with the stalk? If so, do I need to replace the entire column switch? Thanks!! Scott S
- A pile of British stuff - A growing pile of German stuff ... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....) |
Yes they should flash. The stalk is probably burned. You might be able to bodge it if your clever.
You should also fit a relay for your high beams, to prevent this problem for the normal high beam.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Switch.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Mine would flash over every bump until I did this fix. Very easy and worked perfectly.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Thanks!!!!
