Scott S's Avatar
SHould lights flash?
Hi All -
I have been going through every bloody system in my car this winter. I thought I was down to only one issue, until I noticed something last night - my headlights do not flash.
When I pull the stalk, should they? (my car is a 77).
All other dash controls, lighting, turn signals, high beams, etc - even the trunk lights - are unmolested and work perfectly.
Should I be able to flash my lights with the stalk? If so, do I need to replace the entire column switch?
Thanks!!
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 03-17-2015, 09:02 AM
safe's Avatar
Yes they should flash. The stalk is probably burned. You might be able to bodge it if your clever.
You should also fit a relay for your high beams, to prevent this problem for the normal high beam.
Magnus
Old 03-17-2015, 09:26 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Switch.
Do a search for headlight switch cleaning.
turn signal switch quick fix pictures
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-17-2015, 09:44 AM
Good luck,
Gerry
Mine would flash over every bump until I did this fix. Very easy and worked perfectly.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 03-17-2015, 09:53 AM
Scott S's Avatar
Thanks!!!!
Old 03-17-2015, 10:02 AM
