Seat belt interchangeability?
How different, if any, are the mechanicals in DOT-spec 3-pt retracting harnesses over the years? Couldn't find a definitive answer on the internet.
Basically, will the "tongues" and receptacles from different vehicles/models mate correctly, within Porsche or German families (e.g. VW, Audi, BMW, MB, 911, 914, 928, 944, Boxster, Cayman, etc.) and other makes? Any other issues?
Thanks,
Sherwood
Old 05-13-2015, 10:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
When I AXed for the first time PCA wanted me to update my belts since they were too old.
The new ones has a bigger hole but outer design was the same. I was worried they would not fit the receptacle but it worked perfectly. No issues at all. I hope this helps???
'85 Carrera Targa
PCA/POC
Old 05-13-2015, 11:02 PM
The PO put a complete set from a Honda in mine! No interchanging various components.
Tom
Old 05-14-2015, 12:48 PM
Depending on how new you go there is one major issue you need to consider. In the late 90's/early 'aughties many manufacturers switched to load-limiting retractors. These devices, designed for use in conjunction with airbags, allow the belt to play out rather than simply locking up hard, with the result being a more gentle 'ride down' into the big cushy airbag.
It's great, until you try and use one without an airbag...
'90C4
Old 05-14-2015, 05:19 PM
I put in a set of 964 seats into my '74 911 - the seats are vertically identical. My original seatbelts wound not snap into the recepticals (which are built in to the 964 seats rather than floor mounted on the '74). I then bought a set of 964 seatbelts but the mounting bracket under the rear side panels on the '74 is slightly different - this was not a big deal as the bracket is removable and a 964 style will bolt right up. You could also drill a new stabilizing hole on the bracket but I chose to search eBay and found one pretty quickly.
I'm guessing the 944 recepticals are the same as the 964 since they are also mounted directly to the seat.
Old 05-14-2015, 05:28 PM
