Car starts in winter but not in summer.. help
For the last couple years my car will start up with one turn of the key in winter perfectly.
But in the summer or once we hit about 85 (in Mississippi that is now), my SC (81) is very reluctant to start. I can keep the key turned for 30 seconds (or longer) with the starter going and it won't start. I have to do that twice to get it going. I thought accumulator (vapor lock) but this problem happens after a week of sitting around. I'm all a loss.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche Last edited by khamul02; 03-18-2015 at 09:03 AM.. |
Member 911 Anonymous
What is the voltage of the battery in the summer?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Be sure your ignition/electronics are in order before diving into the fuel delivery. The heat may be just enough to raise resistance enough to cause issues with the ignition or the DME.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
It is a new battery but I will give it a check. I did replace the alternator but this problem was happening before and after that replacement.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
i would check fuel pressures first.
Fleabit peanut monkey
Skip the 30 seconds. If you spin for that long AND the cold start valve is working the whole time (sprays when starter is turning) you have flooded it.
Check the Cold Start Valve sensor connections on the driver's side chain cover. 85 degrees ambient is getting closer to the sensors self cut off point (115F or something around there). A poor connection may hamper it's ability to make the ground needed to engage the CSV. Another trick is to turn the key to "on" and lift the air sensor up for a second to get fuel pressure built in the lines. It helps if the CSV is not working.
1981 911SC Targa |
You guys have given me some good places to start. The thing that really puzzle me is how it starts perfectly in sub 80 degree weather.
El Duderino
It's CIS right?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
if it is getting too much fuel the really cold starts will be good. too much on the warm days is bad.
Check the connectors too. I had a hair line split on my positive side and gave me such a headache.
Thank you all for the help. Will report back after the weekend!
Bob, where is the air sensor that one lifts to build fuel pressure? Got a pic?
1986 Bosch Icon Wipers coupe. |
Is he talking about here: http://i262.photobucket.com/albums/ii93/BellCityDubber/42292149.gif
Take off the air filter and look into the intake or feel it with your fingers. Put you hand under the plate and lift slowly. The fuel pump should begin to run and pressure will build until you hear/feel the injectors shoot fuel.
ROW '78 911 Targa
Get the wur cold fuel pressure measurement. Odds are it is too low.
High Humidity. Condensation in dizzy. One of the most humid States in the Country.
I still think it should run/fire with a functioning cold start valve, even if briefly. Condensation in the cap is a good thought also. Even if 85 thru the day it is chillier at night.
1981 911SC Targa |
ROW '78 911 Targa
My thought is it is too rich when cold with the CSV and perhaps low wur system pressure. After 30 seconds of cranking the temperature of the tts rises enough and cuts out the CSV, leaning out the mix and it starts and runs.
Theory only, we need the complete set of fuel pressure readings to deduce more. |
How do I get the required fuel pressure readings? Is there a thread? I'm still a noob.
El Duderino
