			yes I measured the resistance, but at the sensor plug in the engine bay, not at the dme connector.
	85 Carrera 2011 Cayenne Turbo  |
			Thanks.  Anyone know what the proper reading (at the plugs in the engine bay) is supposed to be?  I'd like to test mine to see how it compares against a known good value.
	'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
			I got the upper sensor out but can’t get the lower one.  Soaked it with PB Blaster and it turns freely but will not pull out.  Anyone have any suggestions or words of wisdom to share?
			Remove the bracket, put it in a vice and pull the sensor out. You might be able to turn it but not pull it out because the sensor metal case is sticking to the bracket.
			I had to drill it out with a 15mm bit, but I was replacing it anyway. And I saved the bracket.
	Gilles RoW 88 Carrera coupé  |
 CHT is similar: 1k Ohms at 68F. You can ALSO measure for VAC when cranking: you should see a small +VAC pulse on the speed sensor and a very small VAC (about +0.2VAC IIRC?) blip on the ref sensor.
	1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic CR calculator: https://dcr.questionable.services/  |
			@wazz THANK YOU!  You were 100% correct, the sensors plastic body was seized in the bracket and was allowing the plastic portion to turn and not the metal portion.  Removed the bracket and used a small socket to pound it out.  The attached a 0.8 mm washer to old sensor to relocate the sensor correctly to the flywheel.
