Senior Member
Installing used torsion bars
When installing used torsion bars, do they have to be re-installed in the same side as before? Did not know if they "take a set" from being on another car.
If you buy a used set and have no idea how they were mounted, what is the proceedure? Are they marked in any way to show rotation or position? TIA, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Yes, they take a set and should not be reversed. Unless they are aftermarket, they will have "R" and "L" on the ends to indicate side.
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Senior Member
TT,
Am looking at Sanders and Sway Away bars. Are they marked? Thx, Joe
I think the solid Sway-aways may have marks, but the hollow bars do not, since the end of the bar has no surface for the marking stamp (it is, after all, hollow-there's a space there, not a surface!)
You should be able to tell from the wear marks on the splines of a used bar which side they were on, however, if they are apparent. The loads from the suspension will deform the splines on one side or the other. You might need a magnifying glass to tell on a bar with little wear, though, and then go through the mental exercise of picturing how the loads are applied at each end of the bar according to which side they were installed on. TT
Insert Tag Line HERE.....
The hollow ones also have a stamp on them. There is a small lip on the end. There usually is one set of splines that are an inch or so longer than the other end. I *think* the short side goes to the outside. You can look at the old ones you take out and see what I mean. Geez, I just put some in last week, and I cant remember!
Senior Member
Thanks guys! Just what I was looking for! Now to find the bars at a price I can afford!
![]() Joe
This should make you cry,. It sure made me cry!! After I installed the 32 bars I sat the 28's on the table (in the shop at the dealership) and when I came in Monday, the cleaning crew had tossed them out.!!! AAARRGGHHH!! I was gonna sell them for @ 175 or so..
The orientation of the bar is easy to determine, since the spline count is different on each end. The early bars have 44 teeth on the outside and 40 teeth on the inside. The later bars have 47/46 teeth ('87-'89). They won't fit backwards.
Schleprock
That's right, the Sander bars are not L/R designated. Not prestressed like the factory bars.
Kevin L '86 Carrera "Larry" |
I agree with the Sanders bars, but the Welts/SwayaWays are marked.
